- Thank you received: 394
- newbynobi
it's me who is working on the code
I have thought about that already, but had other thinks to do, so I pushed that away for a while. You are right, the sliders are not very good to handle the speeds. You can connect MPG to that sliders, just look at gmoccapy_jog_wheels.ini, as an example with virtual jog wheels.add a +10% and a -10%
NEVER! I will do that, it is very dangerous!Add a lock button inside the X Y Z. hit lock and either X+ or X- and the axis will move until you hit the limits.
Remove the continous button. Make the remaining buttons larger. key the 4 remaining buttons to:
.0001 per click on MPG or single button click to .100 IPM feed in lock
.0010 per click on MPG or single button click to 1.00 IPM feed in lock
.0100 per click on MPG or single button click to 10.0 IPM feed in lock
.1000 per click on MPG or single button click to 100. IPM feed in lock
Just edit your INI File, than you get the results you wish, except removing the continuous button, it will appear automatically.
Give outputs for all so that MPG wheel can act accordingly.
also any press on a button X+ or Y- will change the focus for the MPG wheel. give me an output for this.
The inputs for the MPG Wheels are already included, see above and the WIKI for details.
The focus change can be done with hal connections.
Let me think a little while about the +10 % and -10 % button, may be there is a way to include them.
Norbert
- jbunch
On my HAAS Mill and the Lock button is great. Like I said it allows for facing etc without having to program.
It is how they teach you to do manual facing, Keyways, etc.
You have to hit the lock and then the direction of movement. IE + -X to stop hit the lock or any key x or y or z or on my mill open the door. if you hit direction and then lock it will not lock the feed on.
I use it every day.
home mill, use the lock and x- to move table to center. All of my one off facing I use the lock.
Just thought I would plead my case one more time. I do understand your point as alot of people do not have enclosed machines.
Although the the older TM series mills and TL series have the same functionality without a full enclusure with doors and door locks. (although I did defeat on of the door locks I had to leave one in to start the machine.)
Also these machine have hard buttons that are more positive then a touch screen.
Sent a partial pictures of the control also. Shows the axis section and the Overide section.
Thanks for looking at my ideas. I know a project like this is a lot of hard work.
Jim
- newbynobi
I will look at the 10% button, but i will not include a feed lock option!
You still have the option to do that in two ways:
- just use an mdi command, you can put several ones as macro button on the screen, that option is explained in detail in the wiki.
- just add a button as side panel to lock the feed. The button can switch a flipflop to lock the feed, and will be reset by any other option. All done in hal.
I personaly use the macros for your purpose. Using one macro I face down, turn to a given diameter and length an make a champfer. Macros do ask you for parameters if you like.
Norbert
- jbunch
Do you support the NGC GUI macros?
if so how do set it up.
Jim
- jbunch
It looks like in your implementation there is no output from Gscreen for:
gscreen.jog-enable-x.out
gscreen.jog-enable-y.out
gscreen.jog-enable-z.out
gscreen.jog-enable-?.out
If you press a +Y or -Y the focus should change to (gscreen.jog-enable-y.out) until diferent axis jog buton has been pressed. The focus shoud then change to that axis.
I have looked in hal meter and these outputs do not exist.
Jim
- newbynobi
gmoccapy does support NGC GUI Macros. There is a sample config in /configs/sim/gmoccpy/ngcgui.
I can not see a reason for that pin. If you jog with the keyboard pressing the corresponding keys a axis will jog.
Do you want to use that pin to combine your hardware MPG Wheel with the keyboard and gmoccapy?
If you use a Jogwheel, you should have on that handle also a button to select the axis and only if holding down that button the JogWheel should work (Dead man security). What happen, if you enter a MDI command, you will sure press the keys you mentioned, so this option should not work in MDI or AUTO Mode. Now you push X. and move the machine using your JogWheel. A Telefon call and your cat throw down the jogwheel pendant, if it moves the Wheel the machine will move, correct.
I am a little bit crazy related to security, that why this is not included.
Norbert
