- Thank you received: 394
- newbynobi
12 years 10 months ago #42156
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
gmoccapy 0.9.9.7
ver. 0.9.9.7
- make gmoccapy react to external mode changes, i.e. start program with
net start halui.mode.auto => halui.program.run <= hardware.button
can be used, but....
I strongly recommend to check for the state with halui.mode.is_auto within your hal and only enable halui.program.run if the GUI is in auto mode!
I took all precautions to avoid starting a program when it is not secure, i.e. you should get an error if you try to start the program using halui, if you are in settings mode, as I force manual mode for that pages!
I would prefer to make my own "halui" pin, but that has to be discussed with the other developers first.
Norbert
ver. 0.9.9.7
Norbert
- newbynobi
12 years 10 months ago #42162
by newbynobi
gmoccapy 0.9.9.7.1
Attention : Hal pin renaming!!!!
ver 0.9.9.7.1
- replaced the hal_scale_jog_vel with a normal scale,
as there is no need for a additional hal pin
- renamed hal pin
gscreen.hal_hbar_spindle_feedback to be gscreen.spindle_feedback_bar
gscreen.hal_led_spindle_at_speed to be gscreen.spindle_at_speed_led
This way all spindle pins are together in halshow
Norbert
ver 0.9.9.7.1
- renamed hal pin
Norbert
- mariusl
12 years 10 months ago #42164
by mariusl
I have to agree with Jim. I always build my machines with a start, stop and pause button external. I think it is needed as a feature.
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
jbunch wrote: Norbert,
I cannot think of any reason not to use a provided pin for run program.
Consider stop, pause, resume as well.
Your fix for the program exit should work.
Thank you
Jim
Regards
Marius
www.bluearccnc.com
- newbynobi
12 years 10 months ago #42166
by newbynobi
Halo Jim and Marius,
with the last push, all your wishes should work, using the known halui pin.
Please test and let me know. If this does not work as expected, I will introduce my own pin, but I try to avoid to code something otheres have done allready, unless I need to.
Jim,
The Exit Button behavior is still the old one, as I will make that feature selectable on the settings page, but first I wnat to finsh tool measurement.
Norbert
Jim,
Norbert
- newbynobi
12 years 10 months ago #42173
by newbynobi
gmoccapy 0.9.9.7.2
New gcode.lang file,
resulting in better gcode highlighting.
Norbert
Norbert
- newbynobi
12 years 10 months ago - 12 years 10 months ago #42205
by newbynobi
gmoccapy 0.9.9.7.3
- modified a little bit the gmoccapy_plasma screen, now also the speed info tab is hidden to make the rest fit better
- plasma.py now supports persistence variables, meaning the values are saved on closing the GUI and restored on restart of the GUI The values are stored in a file called plasma.var in the config dir.
Marius has began to make a very informative gmoccapy_plasma WIKI
Norbert
Norbert
Last edit: 12 years 10 months ago by newbynobi. Reason: typo
Moderators: newbynobi, HansU
Time to create page: 0.682 seconds
