- Thank you received: 202
- cncbasher
12 years 9 months ago #42486
by cncbasher
looking forward to testing
Replied by cncbasher on topic Gmoccapy - A new screen for linuxcnc
newbynobi wrote:
The reason that I am going to the script is because I used Gcode to do toolchange and found that if I use a call to a subroutine or a macro, the back plot does not display the job any more. I have a macro on a button that does the tool length measurement.
I am nearly sure, that your sub does end with an M2.
Replace the M2 with a % only at the end!
I do know that that causes an error in the terminal, but in my case that solved the problem of repainting the preview window with nothing.
Please inform if that works for you too.
If you have a tool length probe switch, you do not need to touch off every tool, in gmoccpy it will not even be necessary to have a reference tool.
You measure any tool you want (in coordinate system later be used on the program), and then you enter the workpiece height (measured from the table), that's it.
Start the program, TnM6 will be found the machine moves automatically to the tool length switch and measure the length, G43 will be activated, as the tool switch height and the workpiece height is known, I can calculate the offset to apply to the actual coordinate system
The tool moves to workpiece and does his job, after the next tool change the same happens again, but now the difference between workpiece height and coordinate system is null, the coordinate system will not be moved.
I am on the tests with real machine at the moment.
Norbert
12 years 9 months ago #42489
Replied by andypugh on topic Gmoccapy - A new screen for linuxcnc
One thing to be aware of here:
Setting LinuxCNC to EMC_TASK_MODE_MANUAL explicitly sets the machine into JOINT mode (If I am correctly interpreting this code, the emcTaskSetMode function
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...5242101;hb=HEAD#l213
I think that The Axis GUI works round this by restoring the mode to TELEOP afterwards.
This is not a problem at all for a trivkins machine.
It works OK on a non-trivkins machine as lone as HALUI is not loaded.
With a non-trivial kins and HALUI active, things are pretty buggy. Has Gmoccapy been tested in this config?
You would not want to be jogging a gantry during tool-change with non-trivkins + halui and Axis...
- mariusl
12 years 9 months ago #42490
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Andy
I am using a standard three stepper config with Gmoccapy. So I am fairly sure it is trivkins and Halui is loaded. If nothing goes wrong in between and you dont have to restart the process, it seems to be ok. Only thing is you have to change the mode to AUTO by hand before closing the dialog.
Regards
Marius
www.bluearccnc.com
- newbynobi
- Thank you received: 394
12 years 9 months ago #42507
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Halo Andi,
I do not even know the difference between joint and telop mode.
So, no it has not been tested, as i only own lathes and mills with 2, 3 and 4 axis.
I will not allow jogging duringbtool change, but i will remape the toolchange to a subroutine, so all machine movement will be done with gcode or MNL commands.
Is there then also a problem?
Halui is not necessary for gmoccapy, but i can not avoid that users do load it.
Norbert from phone
Norbert from phone
- mmprestine
12 years 9 months ago #42519
by mmprestine
Replied by mmprestine on topic Gmoccapy - A new screen for linuxcnc
Hello everyone. I would really like to test out the gmoccapy and cannot seem to get it running. There seems to be an error with my dev version as the .hal files are corrupted. The linuxcnc load of the gmoccapy fail every time on the load of the .hal files and when I try to open them to determine the cause they seem to be damaged.
Any thoughts?
Matt
Any thoughts?
Matt
- newbynobi
12 years 9 months ago #42520
by newbynobi
Hallo Matt,
what version do you use?
Did you just get a git copy?
Are you in sim mode or on a real machine?
Did you make rip-environment before starting the GUI?
What is the exact error message?
Do you know the WIKI?
Norbert
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.483 seconds
