- mmprestine
12 years 9 months ago #42521
by mmprestine
Replied by mmprestine on topic Gmoccapy - A new screen for linuxcnc
Norbert,
I current have a master branch 2.6.0-pre0-3204-g8db1115 installed into a VM for testing.
I used the version of gmoccapy from git so I assume that it is the latest.
I am trying to run in sim mode and those are the .hal files I seem to have issues with.
Not sure that I am familiar with the rip-environment but will check on that.
I looked over the wiki and did not see anything that helped.
Matt
Matt
- newbynobi
- Thank you received: 394
12 years 9 months ago #42523
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
In the virtual machine, do the following:
Do you use virtualbox, or an other virtual machine, virtualbox is ok but vmware some times makes problems.
Norbert
sudo apt-get install git-core gitk git-gui
git config --global user.name "Your full name
git config --global user.email "you@example.com
git clone git://git.linuxcnc.org/git/linuxcnc.git linuxcnc-dev
sudo apt-get install libboost-python-dev libmodbus-dev
cd linuxcnc-dev
cd src
./autogen.sh
./configure
make
sudo make setuid
cd ..
. ./scripts/rip-environment
linuxcnc
Norbert
- mmprestine
12 years 9 months ago #42526
by mmprestine
I am using VMware so perhaps there is an issue there.
I have already done what you have posted but re-ran again.
There seems to be a problem with getting libmodbus-dev:
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Couldn't find package libmodbus-dev
There also seems to be an error with the make:
linuxcnc-dev/src$ make
Makefile:55: Makefile.inc: No such file or directory
Makefile:66: *** Makefile.inc must specify RTPREFIX and other variables. Stop.
Matt
Matt
- newbynobi
12 years 9 months ago #42533
by newbynobi
Please try from virtualbox, and install on it the 10.04 LinuxCNC CD, then run the code I posted and everything will work out of the box!
Norbert
Norbert
12 years 9 months ago #42534
Can I suggest that it would be useful to try running the gantry/gantry sample config, and see how things work out? That is a parport config, so doesn't know that there is no hardware connected.
If you modify it to load halui it would be useful to know if it randomly drops back to joint-mode.
Replied by andypugh on topic Gmoccapy - A new screen for linuxcnc
mariusl wrote: Andy
I am using a standard three stepper config with Gmoccapy. So I am fairly sure it is trivkins and Halui is loaded. If nothing goes wrong in between and you dont have to restart the process, it seems to be ok. Only thing is you have to change the mode to AUTO by hand before closing the dialog.
- mariusl
12 years 9 months ago #42694
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Hi Norbert
I am busy testing the mill functions of Gmoccapy and found that I cannot highlight a line of code to show it in the backplot nor does the code highlight when a move is selected on the backplot. If I want to use "Run from line" then these two functions should be active.
Regards
Marius
www.bluearccnc.com
Moderators: newbynobi, HansU
Time to create page: 0.207 seconds
