12 years 9 months ago #43091 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Halo balestrino,
you are just to fast for me ;-)
I have not even pushed the needed files;-) Because I think the doku must be done first, please stay on the threat, I will inform as soon I pushed all necessary files.
Norbert
12 years 9 months ago #43094 by newbynobi
gmoccapy_0_9_9_9
tool change with tool length measurement
ver. 0.9.9.9
- gmoccapy is now able to do auto tool measurement after an manual tool change
- introduced a ini config to simulate that
- still to do: If user clicks on aboard while the tool change message window is still open
or he closes the window with the small X on the right upper corner, the hal pin will
not be reset properly
Please do not test this, without reading the WIKI and it might help to watch the related videos on you tube.
Please do not comment my very perfect machine with the vise glued with tabe on the table ;-)
Norbert
The following user(s) said Thank You: f1oat, balestrino
12 years 9 months ago #43115 by f1oat
Replied by f1oat on topic Gmoccapy - A new screen for linuxcnc
Norbert, nice job, thanks.
On my side, I have implemented few features for Gmoccapy in a wrapper.
You can get my full config from here: blog.f1oat.org/linuxcnc/
May be you can take some code to enhance Gmoccapy.
It provides:
  • automatic tool table update based on special tags in ngc file
  • automatic handling of reference tool length when Z probing is used
  • block G-CODE window update when running subroutines
  • Automatic probing of the workpiece thanks to a small piece of PCB used as a contact area. Handle the PCB thickness.
  • Automatic tool length measurement and compensation
  • Machine park feature
  • Goto manual tool change position
  • JOG-WHILE-PAUSED feature based on M60 REMAP
  • Tested with Gmoccapy 0.9.9.8.1
My automatic tool length measurement may be redundant with what is now integrated in the last Gmoccapy release.
I have to check if it does the same things.
Frederic.
The following user(s) said Thank You: balestrino
12 years 9 months ago #43130 by newbynobi
Halo Frederic,
thanks a lot for sharing your work.
I will take a closer look to that, as you included some interesting features!
Norbert
12 years 9 months ago #43134 by mariusl
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Hi Norbert
I like some of the stuff that Frederic has done. Like the measurement of the block with a piece of pcb. I do that now with a macro. The park and tool change postions is also a good feature. I would just put the extras on another tab maybe or page maybe.
Regards
Marius
www.bluearccnc.com
12 years 9 months ago - 12 years 9 months ago #43155 by newbynobi
gmoccapy 0.9.9.9.1
Solves most of the tool touch off issues mentioned by Jim.
Only for users who are used to take the Comma as decimal separator and do use a keyboard , there is still a problem with calcwidget, used in the entry dialog, as it will not accept the comma, so please use the dot of your keyboard, until there is a solution.
Norbert
Last edit: 12 years 9 months ago by newbynobi.
Moderators: newbynobi, HansU
Time to create page: 0.682 seconds
