- Thank you received: 394
- newbynobi
12 years 8 months ago #43648
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Hallo Jim,
let me check tomorrow, as I am going to sleep now
Could you please answer the following questions?
- I assume you are running 0.9.9.9.5 , correct?
- Did the program run through, or did you stop/pause it?
- In sim mode or your real hardware?
- Do you use gscreen / gmoccapy toolchange or hal-manual-toolchange?
Norbert
Norbert
- jbunch
12 years 8 months ago - 12 years 8 months ago #43649
by jbunch
Replied by jbunch on topic Gmoccapy - A new screen for linuxcnc
Norbert,
No problem sleep is good. Must be about 24:00 your time.
Your about +9hrs on me.
We are snowed in so I have time to play today.
I updated off f master yesterday.
I stop/paused the program.
I have also rn a program thru to the end.
Only real hardware for me. I have no sim setup. This is setup on a backtool lathe.
I only use gscreen/gmoccapy toolchange.
JIm
JIm
Last edit: 12 years 8 months ago by jbunch.
- newbynobi
12 years 8 months ago #43656
by newbynobi
Hallo Jim,
I can reproduce the bug!
I will try to solve as fast as possible!
Norbert
Norbert
- newbynobi
12 years 8 months ago #43661
by newbynobi
gmoccapy 0.9.9.9.6
- solved show tooledit bug
ver. 0.9.9.9.6
- solved show tool edit after program run
after running a program and changing back to manual mode it was not
possible to enter again the tool edit tab, as we where taken to MDI mode
this was mainly caused by the check for G43 being active.
- changed some print "" commands to be a function print("")
Norbert
ver. 0.9.9.9.6
Norbert
- newbynobi
12 years 8 months ago #43662
by newbynobi
gmoccapy 0.9.9.9.7
- highlight gcode line by grafics click
ver. 0.9.9.9.7
- add gcode highlight by clicking in the preview
clicking a line in the preview will highlight the
corresponding line in gcode listing
Norbert
ver. 0.9.9.9.7
Norbert
- newbynobi
12 years 8 months ago #43663
by newbynobi
gmoccapy 0.9.9.9.8
Toggle Button Setup was not handled correct, if used with momentary hardware switches
Corrected that.
Norbert
Corrected that.
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.406 seconds
