- bjames28
13 years 7 months ago #31711
by bjames28
Replied by bjames28 on topic Gmoccapy - A new screen for linuxcnc
Hi Chris,
This was really a prompt answer. Thanks.
I know that Gmoccapy is running only on master. That's why I wrote that perhaps I shouldn't mix the two versions.. On 2.5.2 it was deb package, just the "icon" issue is similar. (debs I used for 2.5.2: code.google.com/p/moccagui/downloads/list )
Thanks for the further investigations.
Maybe I can try it on RIP system too. I built RIP only once.
Regards:
James
Regards:
James
- newbynobi
- Thank you received: 394
13 years 7 months ago - 13 years 7 months ago #31797
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Hallo James,
sorry to answer so late, but I have been skiing in Austria last week.
Please do not mix moccagui and gmoccapy! This are completely different thinks, only the look and feel is similar.
please get a new clone from master and compile as run in place, than you will get all the benefits off gmoccapy.
I will soon make some new videos as tutorials.
@ chris,
thanks for pushing my little peace of work to master and for opening this thread.
Norbert
@ chris,
Norbert
Last edit: 13 years 7 months ago by newbynobi. Reason: to many mistakes in ortography
- bjames28
13 years 7 months ago - 13 years 7 months ago #31798
by bjames28
Hi Norbert,
Is there a way to have the icons in moccagui for LinuxCNC ver 2.5?
I am using gmoccapy 2.6 from buildbot. Should it work, or only the RIP version is the intended way?
I copied all missing icons from git repo to the local folder and it solved the issue.
I want to create kind of "appetizer" for local LinuxCNC community, that's why I insist on icons. You know, icons are international by default, so you don't have to translate them to local language.
Thanks for assistance.
Best regards:
James
Best regards:
James
Last edit: 13 years 7 months ago by bjames28.
- newbynobi
13 years 7 months ago #31871
by newbynobi
Hallo James,
I just builded a virtual machine and tried gmoccapy under buildbot.
Unfortunately buildbot does not include all the sub folders from gmoccapy, not only the icons folder is missing, also the subroutine folder, so you will not be able to execute macros in MDI mode.
May be Chris can give us a hand, finding out, why the sub folders are missing.
Please use until then a git copy from master. It has just been updated to ver. 0.8.6, and does now export HAL pins to adjust the sliders for jog-velocity, Max-veloxity. feed-overide and spindle-overide with attached MPG wheels.
You will find an example how to connect the MPG wheels to the hal Pins in gmoccapy_postgui.hal. The lines are commented out, because the use a parport and otherwise the sim version will not work.
To include the icons in moccagui, you will have to edit the corresponding XML Files of that GUI.
Again: moccagui and gmoccapy are not the same and are written in different languages!
To all: I am just begining to write a wiki page and I could need some help, so feel free to participate
gmoccapy wiki
Norbert
gmoccapy wiki
Norbert
The following user(s) said Thank You: bjames28
- tjamscad
13 years 7 months ago - 13 years 7 months ago #31907
by tjamscad
Replied by tjamscad on topic Gmoccapy - A new screen for linuxcnc
I found build comming up short when I tried it also. I recomend building from source. I have done this and Gmoccapy works just fine. Here is my in stall script, it builds a simulator and works in 12.04 and 10.04. Just edit out what you dont need but, it will install and Gmoccapy works as intended. Make sure you set the permissions to run as program.
Last edit: 13 years 7 months ago by tjamscad.
- newbynobi
13 years 7 months ago #31908
by newbynobi
Have you forgotten to add the install script?
I think it would be a good Idea to include your script in the WIKI page.
Norbert
Norbert
The following user(s) said Thank You: tjamscad
Moderators: newbynobi, HansU
Time to create page: 0.212 seconds
