Please help me for uptate axis 2.5.4 to Gmoccapy
- Weiler810T
- Visitor
28 Oct 2017 10:55 #100918
by Weiler810T
Please help me for uptate axis 2.5.4 to Gmoccapy was created by Weiler810T
Hello
I need help with the implementation from Axis 2.5.4 to Gmoccapy, i am a neeby in things Linuxcnc. Here is my configfolder:
thank you ever in advance:)
greetz Siggi
greetz Siggi
- newbynobi
- Thank you received: 394
28 Oct 2017 11:56 #100919
by newbynobi
Replied by newbynobi on topic Please help me for uptate axis 2.5.4 to Gmoccapy
Hallo,
being a newby, that is quiet a complicated configuration.
We need to do the change in various steps, as I do not have such a nice hardware to test here
The biggest stuff will be the change of your custom panel from pyvcp to gladeVCP, as gmoccapy does not support pyvcp!
OK, lets begin:
Make a copy of your config folder!
Open the ini file and delete the entries:
change:
DISPLAY = axis
to
DISPLAY = gmoccapy
open a terminal and enter
linuxcnc
select the new config and start it.
I am sure the config will not start, so please watch the output in the terminal and post it here, so we can take the next step.
Norbert
OK, lets begin:
PYVCP = pyvcp.xml
POSTGUI_HALFILE = pyvcp.halchange:
DISPLAY = axis
to
DISPLAY = gmoccapy
linuxcnc
Norbert
- Weiler810T
- Visitor
28 Oct 2017 13:55 - 01 Nov 2017 11:06 #100924
by Weiler810T
Replied by Weiler810T on topic Please help me for uptate axis 2.5.4 to Gmoccapy
Ok, Norbert,here is the first test result:
Print file information:
Moderator deleted unneeded lines:
Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/Nullen.ko: Invalid module format
./loadrt.hal:7: exit value: 1
./loadrt.hal:7: insmod for Nullen failed, returned -1
See the output of 'dmesg' for more information.
Last edit: 01 Nov 2017 11:06 by newbynobi.
- newbynobi
28 Oct 2017 14:12 - 28 Oct 2017 14:15 #100925
by newbynobi
Is this the same computer?
Linuxcnc has problems to load a realtime component.
This is the relevant part:
but it could be caused, because there is a problem loading the realtime part.
Have you changed any path settings?
Please try to uncomment the following hal files:
try again and report.
Norbert
./loadrt.hal:7: insmod for Nullen failed, returned -1but it could be caused, because there is a problem loading the realtime part.
#HALFILE = loadrt.hal
#HALFILE = Maschine.hal
#HALFILE = Spindel.hal
#HALFILE = Bedienfeld.hal
#HALFILE = Werkstückwechsler.hal
#HALFILE = Werkzeugwechsler.hal
#HALFILE = Handrad.hal
#HALFILE = Meldung.haltry again and report.
Norbert
Last edit: 28 Oct 2017 14:15 by newbynobi.
- newbynobi
29 Oct 2017 09:55 #100967
by newbynobi
Together we will be able to redo that part
OK, lets go on with small steps:
Are the other custom comp files also copies of an old system?
The following components seem to be custom ones.
Could you post the code of them, so I can try to see what is wrong, or if they just need to be compiled again under the new OS?
If you do have the source code, you can easy recompile them, i.e. for Nullen:
More Details are in:
comp docs
Norbert
loadrt Nullen
loadrt Meldung
loadrt Spindel
loadrt SF
loadrt WZW
loadrt WSW
loadrt Increment
loadrt tuerueberwachung If you do have the source code, you can easy recompile them, i.e. for Nullen:
halcompile --install Nullen.compMore Details are in:
comp docs
Norbert
- Weiler810T
- Visitor
29 Oct 2017 11:58 #100970
by Weiler810T
Servus Norbert
The Comp-files are from the old system.Can be that the source-code is still on the hard disk.
I will be back on Wednesday, I have to go to work tomorrow.
Greetz Siggi
Greetz Siggi
- Weiler810T
- Visitor
29 Oct 2017 16:13 #100974
by Weiler810T
YIPIYEAHHH
es funktioniert, its running
root@chiron:~# cd /home/chiron/linuxcnc/src/hal/drivers
root@chiron:/home/chiron/linuxcnc/src/hal/drivers# halcompile --install Nullen.comp
make KBUILD_EXTRA_SYMBOLS=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/Module.symvers -C /usr/src/linux-headers-3.4-9-rtai-686-pae SUBDIRS=`pwd` CC=gcc V=0 modules
make[1]: Entering directory `/usr/src/linux-headers-3.4-9-rtai-686-pae'
CC [M] /tmp/tmpZkMnUD/Nullen.o
Building modules, stage 2.
MODPOST 1 modules
CC /tmp/tmpZkMnUD/Nullen.mod.o
LD [M] /tmp/tmpZkMnUD/Nullen.ko
make[1]: Leaving directory `/usr/src/linux-headers-3.4-9-rtai-686-pae'
cp Nullen.ko /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/
greetz Siggi
MODPOST 1 modules
greetz Siggi
- newbynobi
30 Oct 2017 09:55 - 30 Oct 2017 09:56 #101006
by newbynobi
Hallo Siggi,
ok, thats good. What about your pyVCP panel, do you want to integrate that features also to gmoccapy?
If so, I will make you the glade panel and lead you through the integration.
Have you connected the spindle feedback to the gmoccapy.spindle_feedback_bar hal pin?
And also the spindle-at-speed signal to gmoccapy.spindle_at_speed hal pin?
You may want to connect also the hal pin gmoccapy.tooloffset-x and gmoccapy.tooloffset-z
That way you can take advantage of all gmoccapy features.
Please make sure, that the mentioned hal connections need to be made in a separate postgui.hal
Norbert
Norbert
Last edit: 30 Oct 2017 09:56 by newbynobi.
- Weiler810T
- Visitor
01 Nov 2017 09:37 - 01 Nov 2017 11:02 #101114
by Weiler810T
Ok, next step ,all compiled and Gmoccapy turn on and crashed.
MODERATOR deleted unneeded lines:
Debug file information:
./Maschine.hal:4: Warning: File contains DOS-style line endings.
./Bedienfeld.hal:4: Warning: File contains DOS-style line endings.
./Werkstückwechsler.hal:4: Warning: File contains DOS-style line endings.
./Werkzeugwechsler.hal:4: Warning: File contains DOS-style line endings.
./Handrad.hal:4: Warning: File contains DOS-style line endings.
./Meldung.hal:4: Warning: File contains DOS-style line endings.
pyvcp.hal:4: Warning: File contains DOS-style line endings.
pyvcp.hal:18: Pin 'pyvcp.btn01' does not exist
Siggi
Siggi
Last edit: 01 Nov 2017 11:02 by newbynobi.
- newbynobi
01 Nov 2017 10:58 - 01 Nov 2017 11:09 #101119
by newbynobi
Hallo Siggi,
please do not make the thread so long, by including all the messages as text. Please copy it in a file and post the file, thats makes it easier to follow the thread.
Here is the relevant part:
First of all, never ever edít a hal file in Windows, as you get wrong line endings!
You need to reformat the files,
Rename all the files you need to convert and tryMay be you have to install dos2unix first.
Then comment out the line 140 of the INI, where you do load the pyvcp.hal, That file can not be loaded, as gmoccapy does not work with pyvcp panels. (I mentioned this already in a previous post)
Report.
Norbert
P.S. I edited this thread to make it easier to follow.
/usr/bin/gmoccapy:237: GtkWarning: Invalid icon size 48
self.widgets.window1.show()
(gmoccapy:5909): GtkSourceView-CRITICAL **: gtk_source_language_manager_set_search_path: assertion `lm->priv->ids == NULL' failed
pyvcp.hal:18: Pin 'pyvcp.btn01' does not existFirst of all, never ever edít a hal file in Windows, as you get wrong line endings!
dos2unix Maschine.hal.old Mascine.halThen comment out the line 140 of the INI, where you do load the pyvcp.hal, That file can not be loaded, as gmoccapy does not work with pyvcp panels. (I mentioned this already in a previous post)
Report.
Norbert
Last edit: 01 Nov 2017 11:09 by newbynobi.
Moderators: newbynobi, HansU
Time to create page: 0.185 seconds
