Please help me for uptate axis 2.5.4 to Gmoccapy
  • Weiler810T
  • Weiler810T's Avatar Topic Author
  • Visitor
  • Visitor
03 Nov 2017 08:37 - 03 Nov 2017 08:39 #101216 by Weiler810T
Replied by Weiler810T on topic Please help me for uptate axis 2.5.4 to Gmoccapy
Ok, next step, Spindel is working :) but Spindeldrehzahlfeld not working
Last edit: 03 Nov 2017 08:39 by Weiler810T.
03 Nov 2017 09:29 #101234 by newbynobi
Replied by newbynobi on topic Please help me for uptate axis 2.5.4 to Gmoccapy
OK, my mistake, I took the wrong signal names.
Please find attached a reworked postgui file.
See also the comments in that file.
Norbert
The following user(s) said Thank You: Weiler810T
  • Weiler810T
  • Visitor
  • Visitor
10 Nov 2017 15:47 #101610 by Weiler810T
New Errors :blink:
What is that ?
Debug file information:
(gmoccapy:4954): GdkGLExt-WARNING **: Window system doesn't support OpenGL.
File "/usr/bin/gmoccapy", line 35, in <module>
import gladevcp.makepins # needed for the dialog"s calculator widget
File "/usr/lib/pymodules/python2.7/gladevcp/__init__.py", line 1, in <module>
from hal_pythonplugin import *
File "/usr/lib/pymodules/python2.7/gladevcp/hal_pythonplugin.py", line 27, in <module>
from hal_gremlin import HAL_Gremlin
File "/usr/lib/pymodules/python2.7/gladevcp/hal_gremlin.py", line 32, in <module>
import gremlin
File "/usr/lib/pymodules/python2.7/gremlin.py", line 40, in <module>
import gtk.gtkgl.widget
File "/usr/lib/python2.7/dist-packages/gtk-2.0/gtk/gtkgl/__init__.py", line 21, in <module>
from _gtkgl import *
RuntimeError: OpenGL is not supported
4862
PID TTY STAT TIME COMMAND
4951
Stopping realtime threads
Unloading hal components
10 Nov 2017 22:06 - 10 Nov 2017 22:16 #101632 by newbynobi
What have you done?
It did work during our teamviewer session!
Now it looks like your system is missing a GL dependencie.
Have you installed python-gtkglext1?
Norbert
Last edit: 10 Nov 2017 22:16 by newbynobi.
  • Weiler810T
  • Visitor
  • Visitor
11 Nov 2017 12:57 #101654 by Weiler810T
Okay, läuft wieder, mußte komplett neu installieren :whistle:
Grüße Siggi
11 Nov 2017 14:33 - 11 Nov 2017 14:34 #101657 by newbynobi
Hallo Siggi,
glad you got it working again, but I am still asking:
What have you done, it is not normal that you did have to reinstall!
Please do not make the same error again ;)
Norbert
Last edit: 11 Nov 2017 14:34 by newbynobi. Reason: typo
  • Weiler810T
  • Visitor
  • Visitor
19 Nov 2017 09:39 - 19 Nov 2017 16:17 #101996 by Weiler810T
Hallo Norbert
Spindeldrehzahlproblem solved :) , added in Spindelumrichter Spannungsoffset=-0,02
Last edit: 19 Nov 2017 16:17 by Weiler810T.
  • Weiler810T
  • Visitor
  • Visitor
26 Dec 2017 10:12 #103626 by Weiler810T
Next Problem :blink: i have whith the automatic tool measuring.(Linuxcnc/gmoccapy/6. Auto Tool Measurement)
Wen aktivatet net tool-prep-loop iocontrol.0.tool-prepare <= iocontrol.0.tool-prepared >Linuxcnc Crashed
I need iocontrol.0.tool-prepared in my Werkzeugwechsler.hal (net WZW-bereitmachen-kurzschliessen iocontrol.0.tool-prepare => iocontrol.0.tool-prepared)
Any Idea?
File Name: Werkzeugwe...2-26.hal
File Size:6 KB
26 Dec 2017 10:31 #103628 by newbynobi
The Doku is just an example.
Imho you do not need the tool measurement pin in your postgui hal file.
What happen if you do not use them?
Norbert
  • Weiler810T
  • Visitor
  • Visitor
26 Dec 2017 10:37 - 26 Dec 2017 10:37 #103629 by Weiler810T
I have to find out first ;)
Last edit: 26 Dec 2017 10:37 by Weiler810T.
Moderators: newbynobi, HansU
Time to create page: 0.152 seconds
