NativeCAM is Features renamed
- FernV
- Thank you received: 124
27 Mar 2017 02:29 #90329
by FernV
We have the following options :
If in tool-change, it means that every finishing cut after be done with that option until you insert another tool-change to change the setting. If in the shape you select it for each one.
I am not sure what is best, maybe I would opt for the shape
What do you think ?
Fern
Replied by FernV on topic NativeCAM is Features renamed
Finishing passes - I wanted my finishing pass to be at the full depth, instead of at stepped depths
If this could be an option in the tool-change.cfg, it'd be better, as sometimes I don't want to plunge the tool the full depth, for example, with long cutters, but short flute lengths. It's not time critical, so I won't be crying out for it any sooner!
- in the tool-change
- in the shape finishing options
What do you think ?
Fern
- orpheus
- Thank you received: 3
27 Mar 2017 07:49 #90333
by orpheus
Replied by orpheus on topic NativeCAM is Features renamed
I'd agree, the most logical place for the option is in the finishing options - it probably makes the most sense.
- yeltrow
30 Mar 2017 20:46 #90604
by yeltrow
Replied by yeltrow on topic NativeCAM is Features renamed
I am getting the following error when I try to start NativeCam on my Deb Wheezy / LinuxCNC 2.7.8 box.
(gladevcp:28585): libglade-WARNING **: Expected <glade-interface>. Got <interface>.
(gladevcp:28585): libglade-WARNING **: did not finish in PARSER_FINISH state
**** GLADE VCP ERROR: With xml file: /home/myusername/Downloads/NativeCAM/ncam.ui : could not create GladeXML object
<commandline>:0: gladevcp exited without becoming ready
Embeded tab command "halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -x 60817565 -U --catalog=mill /home/wortley/Downloads/NativeCAM/ncam.ui" exited with error: 1
I can run it from the directory my mill's ini file sits in and it starts up fine and even knows about the tool table. I just can't get it to run embedded. I did a git pull this afternoon to put the copy into my Downloads directory. I ran it with NO options first, just at ./ncam.py, and then I tried to run it with ~/Downloads/NativeCAM/ncam.py -i theshiz.ini
I have to start linuxcnc theshiz.ini in a separate window first so it is there listening for nativecam to talk to it. I can tell I am just SO CLOSE!!!!
my original config files are in my git repo at github.com/yeltrow/theshiz (although I haven't merged in the nativecam ones, since it doesn't work yet.)
30 Mar 2017 23:30 #90615
Replied by andypugh on topic NativeCAM is Features renamed
-x (actual number) looks suspicious. Are you sure that it right?
- yeltrow
31 Mar 2017 01:24 #90621
by yeltrow
Andy, I can't find that number in any of my config files, or any place that option may have slipped in. I think I saw somewhere in the docs how gladevcp REALLY gets launched, but I haven't figured it out yet. Maybe because I am not running the development branch there is some sort of conflict. I have been able to change the complaints gladevcp has with the xml file, but not find anything that fixes it.
- FernV
31 Mar 2017 03:27 #90624
by FernV
Have you run from ncam directory : sudo python nondeb_setup.py ???
If not then do it and if you did then do it again. Some modifications are
needed to run embedded and when lcnc updates, it overwrites those modifications.
Until a release from lcnc will really integrate NativeCAM, you may have to redo it
a few times
Regards
Fern
a few times
Regards
Fern
- yeltrow
31 Mar 2017 17:11 #90658
by yeltrow
FernV,
I ran it, and I think that helped. My error changed to this:
File "/usr/bin/gladevcp", line 45, in <module>
import gladevcp.makepins
File "/usr/lib/pymodules/python2.7/gladevcp/__init__.py", line 1, in <module>
from hal_pythonplugin import *
File "/usr/lib/pymodules/python2.7/gladevcp/hal_pythonplugin.py", line 1, in <module>
from ncam import NCam
File "/usr/lib/pymodules/python2.7/gladevcp/ncam.py", line 34, in <module>
import pref_edit
ImportError: No module named pref_edit
What I have found is my silver bullet is this:
PYTHONPATH=/home/myusername/Downloads/NativeCAM/:
After that I can get it to start up just fine. Is there a way to build that in to a startup script so I do not have have to write a wrapper script? I have tried stuffing that into a few places, but I haven't found one that works.
Thank you very much for pushing this work forward. It will be FANTASTIC to have this built in. Can I run it as a tab?
import pref_edit
- FernV
31 Mar 2017 17:39 #90659
by FernV
pref_edit.py is a module I added lately by removing code from ncam.py,
code that is only called from times to times
I was not aware that hal_pythonplugin would try to import it . I use a prototype deb package and
development is stand alone most of the time.
I will have a look at this tonight if I can and report to you a.s.a.p
I understand it works after you export this value, am I right ?
I am not very good with script but it could help if you create a script with something similar to this :
export PYTHONPATH=/home/myusername/Downloads/NativeCAM/
linuxcnc 'path to your inifile'
name it like lcncstart.sh
save on your desktop
then double click to start
As I wrote, I can not guarantee it will work but I would try
Regards
Fern
.... I ran it, and I think that helped. My error changed to this:
import pref_edit
Regards
Fern
- yeltrow
31 Mar 2017 17:53 #90660
by yeltrow
FernV,
That type of script would work.
Can this control panel be run as a tab? I wasn't sure how I could come up with the -x option to pass loadusr if I did it myself. It seems like it is some magic random number.
Thanks!
Thanks!
31 Mar 2017 18:11 #90661
Does -x {XID} work?
Time to create page: 2.462 seconds
