NativeCam on LinuxCNC 2.9.3
2 years 3 weeks ago - 2 years 3 weeks ago #311344 by Giovanni
Now NativeCAM is running with Python3 and Gtk "without" problems, at least as standalone.
There are some problems and Gtk deprecations to fix. but it works.
On my Raspberry Pi machine it runs enbedded in LinuxCNC too.
I think all of you could run it as embedded configuring paths etc...
Regards
Giovanni
Last edit: 2 years 3 weeks ago by Giovanni.
2 years 3 weeks ago #311362 by andypugh
Have you considered submitting your fixes as a pull-request to the repository that you got it from?
(or, maybe better, to the original FernV repo, unless that has been abandoned)
The following user(s) said Thank You: jmmontes
2 years 3 weeks ago #311753 by freemoore
Ach, got a bad case of not copying my post text before hitting submit and losing what I'd typed.
Essentially, for me nativecam works still only as a standalone; and goes like this: If I run only the 'ncam.py' command I get the nativecam interface but without connection to the tooltable, and unable to send part programs to lcnc.
However if I include what's supposed to be the setup instructions i.e. ncam.py --ini=/path/to/my/inifile --catalog=mill -t, and start linuxcnc before executing that command, I get ncam as standalone but with the tooltable accessible, and can check the autoupdate box and have it work more or less as it used to when integrated into a tab.
I've had a couple of goes at going through Fernand's instructions that Giovanni attached as a pdf file above but so far no joy; just completed a full reinstall from the lcxnc 2.9.3 iso so have a clean system and will give it another shot.
2 years 3 weeks ago #311765 by Giovanni
Sorry, but I am not able to do that.
Regards
Giovanni
2 years 3 weeks ago #311766 by Giovanni
Sorry, I am short of time, but I have write a short note (excuse me it is in italian)
I hope, integrated with the previous test, maybe it could help.
Regards
Giovanni
2 years 1 week ago #312587 by Giovanni
@freemoore: if you want, we can try to install/configure together.
Maybe we would be lucky enough to get NativeCam full working on your pc.
Time to create page: 0.069 seconds
