NativeCam on LinuxCNC 2.9.3
1 year 8 months ago #321047 by Becksvill
awesome
sorry i didn't check the notify me box so only just stumbled across this.
just getting a bit stuck working out how to download it and install.
ideally a guide would be great. or something. I can go back through the thread and try to see what i missed but any up to date info would be great
i always seem to get caught out in the little details. like i have the wrong repo or just missing a command
but i have done many retrofits so not completely useless:)
but i think i might need a tiny bit of hand holding on this one.
cheers
Andrew
1 year 8 months ago #321116 by Giovanni
I have prepared and tested an installing procedure for Debian systems.
(thank you freemoore for the collaboration)
Maybe youu could be interested.
Regards
The following user(s) said Thank You: gmouer
1 year 8 months ago #322725 by Becksvill
hey there
i have been trying to get your guide working
getting a issue that stops me in my tracks
i just downloaded the latest 2.9.4 iso file.
and i am testing in a virtual machine VM
following your guide halfway through step 3
"then move the NativeCam folder in:
/usr/share/linuxcnc/gladevcp
sudo mv NativeCam /usr/share/linuxcnc/gladevcp
and this fails with the error  mv: cannot stat 'NativeCam' : No such file or directory
everything up to this stage seemed to work
would love any help you have cheers
1 year 8 months ago - 1 year 8 months ago #322878 by Giovanni
Hello,
it seems you have not the folder to move.
Mybe you are in the wrong place.
If you list the folder by typing ls command, can you see the NativeCam folder listed?
Last edit: 1 year 8 months ago by Giovanni. Reason: Syntax
1 year 7 months ago #324448 by HansU
Replied by HansU on topic NativeCam on LinuxCNC 2.9.3
I created a branch with a gmoccapy sample config: github.com/LinuxCNC/linuxcnc/commits/nativecam
to test in a RIP environment.
I added NativeCAM as a submodule from github.com/freemoore/NativeCAM , so you need to run 'git submodule update --init --recursive' for the first time to get its content.
Please let me know if it works for you as well.
The following user(s) said Thank You: gmouer, Aciera
1 year 7 months ago #324610 by Becksvill
hey Giovanni
did you use virtual box for your VM
i am about to try your guide again using virtual box and a stock standard linuxcnc iso 2.93 install
just thinking i could just grab your vm file and work back from there if you used virtual box
cheers
Andrew
Time to create page: 0.065 seconds
