NativeCam on LinuxCNC 2.9.3
1 year 6 months ago - 1 year 6 months ago #325820 by gmouer
Replied by gmouer on topic NativeCam on LinuxCNC 2.9.3
I am having the same issue as Becksvill , that is axis launches with a NativeCAM tab but that tab is empty when opened.I ran linuxcnc from terminal as suggested,   results of that terminal window  attached here.   I also attached the INI file for reference.
George
File Name: errorFile.txt
File Size:1.51 KB
File Name: axis.ini
File Size:5.35 KB
Last edit: 1 year 6 months ago by gmouer.
1 year 6 months ago #325824 by Giovanni
It seems to me you (bothf you) have a problem showing up the interface.
Have you tried to run NativeCAM from the terminal?
1 year 6 months ago - 1 year 6 months ago #325825 by gmouer
Yes, I tried from the terminal,  same.... empty tab.    I posted the results in the terminal window in my previous post.  (errorfile.txt)
Also, I noticed in step 3 of the instructions aux_gladevcp is referenced but there is no such file  YET the verify instructions reference gladevcp  (no aux_)   aux_gladevcp is again referenced in step 9.
One other observation... step 3,  NativeCAM filder is copied into /gladevcp but later the ini file references the path as ncam,   there does not seem to be a ncam folder.     (my very old linuxcnc with nativecam has a ncam folder)
1 year 6 months ago #325828 by Giovanni
I meant run NativeCAM standalone from terminal.
Yes, in step 9 there is an error. Excuse me.
No "aux_gladevcp", but "/usr/share/linuxcnc/gladevcp/", it has to be the same path referenced in step 3.
Watchng the error file you posted, it seems LinuxCNC can't load lxml module as a python module. Have you installed python3-lxml in your system?
Regards
Giovanni
The following user(s) said Thank You: gmouer
1 year 6 months ago - 1 year 6 months ago #325829 by gmouer
not positve about python3-lxml, I know I verified python3 was there from the fresh 2.9.4 install. I am going back into my shop right now to recheck this. Answer soon
Yes, I ran NativeCAM standalone from terminal, that was the "errorfile" I posted.
I have also ran it entering LCNC the normal way.
Last edit: 1 year 6 months ago by gmouer. Reason: CONFIRMED!!! python3-lxml was NOT installed. It is now installed. Same empty tab, checking further now.
1 year 6 months ago - 1 year 6 months ago #325831 by gmouer
Tried standalone NativeCAM again after installing python3-lxml.     Terminal screen info attached in file
Noticed inifile =N/A in terminal.    I think this is because I launched linuxcnc in terminal without specifying in some way thataxis sim is to be used.
Also tried launching Linuxcnc the normal way with axis sim selected.     There is a NativeCAM tab but still remains a empty tab
File Name: stdAloneErrors.txt
File Size:831 B
Time to create page: 0.072 seconds
