NativeCam on LinuxCNC 2.9.3
1 year 6 months ago #326730 by Cynas
Replied by Cynas on topic NativeCam on LinuxCNC 2.9.3
Thank you all for your time for NativeCam,
Does the configuration for the lathe work?
Milling machine and plasma work without any problems, unfortunately configuration but lathe does not start
Thank you for your help
1 year 6 months ago #326752 by Giovanni
I've never tried the lathe option.
How do you run ncam (embedded, standalone...)?
Does it give errors?
Regards
Giovanni
1 year 6 months ago - 1 year 6 months ago #326769 by Cynas
embedded - incomplete view and no proper operation
standalone - it doesn't start
ncam --catalog=mill    - ok
ncam --catalog=plasma   - ok
ncam --catalog=lathe   - it doesn't start, error in the next post
Last edit: 1 year 6 months ago by Cynas.
1 year 6 months ago #326770 by Cynas
linuxcnc@linuxcnc:~/Desktop$ ncam --catalog=lathe
NativeCAM info:
   inifile = NA
  NCAM_DIR = /home/linuxcnc/nativecam
   SYS_DIR = /usr/share/linuxcnc/gladevcp/NativeCAM
   program = /usr/share/linuxcnc/gladevcp/NativeCAM/ncam.py
Using default lathe/menu.xml,  no lathe/menu-custom.xml found
  File "/usr/bin/ncam", line 4124, in get_selected_feature
    if self.actionDualView.get_active():
AttributeError: 'NCam' object has no attribute 'actionDualView'
/usr/bin/ncam:3660: DeprecationWarning: Gtk.ActionGroup.add_action is deprecated
  self.action_group.add_action(act)
/usr/bin/ncam:3658: DeprecationWarning: Gtk.ActionGroup.add_action_with_accel is deprecated
  self.action_group.add_action_with_accel(act, accel)
/usr/bin/ncam:3654: DeprecationWarning: Gtk.Action.set_icon_name is deprecated
  act.set_icon_name(stock_id)
/usr/bin/ncam:2803: DeprecationWarning: Gtk.UIManager.get_accel_group is deprecated
  self.accelGroup = self.uimanager.get_accel_group()
/usr/bin/ncam:3936: DeprecationWarning: Gtk.UIManager.get_action is deprecated
  self.actionSingleView = self.uimanager.get_action("/dummy/SingleView")
/usr/bin/ncam:2964: DeprecationWarning: Gtk.Action.create_menu_item is deprecated
  mi = _action.create_menu_item()
(ncam:1781): Gtk-CRITICAL **: 11:59:35.761: gtk_accel_label_set_accel_closure: assertion 'gtk_accel_group_from_accel_closure (accel_closure) != NULL' failed
/usr/bin/ncam:2966: DeprecationWarning: Gtk.Action.create_icon is deprecated
  mi.set_image(_action.create_icon(menu_icon_size))
/usr/bin/ncam:2966: DeprecationWarning: Gtk.ImageMenuItem.set_image is deprecated
(ncam:1781): Gtk-CRITICAL **: 11:59:35.762: gtk_accel_label_set_accel_closure: assertion 'gtk_accel_group_from_accel_closure (accel_closure) != NULL' failed
(ncam:1781): Gtk-CRITICAL **: 11:59:35.763: gtk_accel_label_set_accel_closure: assertion 'gtk_accel_group_from_accel_closure (accel_closure) != NULL' failed
(ncam:1781): Gtk-CRITICAL **: 11:59:35.766: gtk_accel_label_set_accel_closure: assertion 'gtk_accel_group_from_accel_closure (accel_closure) != NULL' failed
/usr/bin/ncam:2809: DeprecationWarning: Gtk.UIManager.get_widget is deprecated
  self.main_toolbar = self.uimanager.get_widget("/ToolBar")
/usr/bin/ncam:5095: DeprecationWarning: Gtk.ToggleAction.get_active is deprecated
/usr/bin/ncam:5641: DeprecationWarning: Gtk.Action.set_sensitive is deprecated
  self.actionCollapse.set_sensitive(self.selected_feature is not None)
/usr/bin/ncam:5662: DeprecationWarning: Gtk.Action.set_visible is deprecated
  self.actionChngGrp.set_visible(
DEBUG actionDualView.get_active
Previous work not saved as current work
  File "/usr/bin/ncam", line 5923, in <module>
    ncam = NCam()
  File "/usr/bin/ncam", line 2827, in __init__
    self.load_currentWork()
  File "/usr/bin/ncam", line 5068, in load_currentWork
    self.action_new_project()
  File "/usr/bin/ncam", line 5086, in action_new_project
    xml = self.update_features(xml)
  File "/usr/bin/ncam", line 5524, in update_features
    recursive(xml_i, None)
  File "/usr/bin/ncam", line 5465, in recursive
    f_B = Feature(src=src_f)
  File "/usr/bin/ncam", line 1784, in __init__
    self.from_src(src)
  File "/usr/bin/ncam", line 1848, in from_src
    src_config.read_string(str(f))
  File "/usr/lib/python3.11/configparser.py", line 739, in read_string
    self.read_file(sfile, source)
  File "/usr/lib/python3.11/configparser.py", line 734, in read_file
    self._read(f, source)
  File "/usr/lib/python3.11/configparser.py", line 1112, in _read
    raise DuplicateOptionError(sectname, optname,
configparser.DuplicateOptionError: While reading from '<string>' [line 90]: option 'header' in section 'PARAM_Z_RAP' already exists
1 year 6 months ago #327217 by Cynas
Has anyone checked if this works on another computer?
1 year 6 months ago #327241 by cmorley
Replied by cmorley on topic NativeCam on LinuxCNC 2.9.3
I got this same error when working on the qt version (based on python2 stuff).
IIRC I removed the offending entry and didn't notice a problem (but I don't use it)
IIRC I tested a python2 original version and didn't get the error - so my guess is the parsing library is more picky by default now.
I don't know enough about the saving format to make a definitive decision.
Time to create page: 0.398 seconds
