Another plasma component...
- thefabricator03
- Visitor
21 Jun 2019 08:14 #137464
by thefabricator03
Rod,
Do you mind sharing your sheetcam post for Plasmac that has the new disable function.
Replied by thefabricator03 on topic Another plasma component...
Anyway, the good news is once I had pins that actually got the adaptive feed working, I sorted out some code snippets and cutting rules for holes for Sheetcam and it all works nicely.
Rod,
- Thank you received: 4151
21 Jun 2019 08:47 - 21 Jun 2019 08:47 #137469
Yes, I will when I'm back at work. I did not change much today, the magic is in the cutting rules., not the post processor.
Rod,
Last edit: 21 Jun 2019 08:47 by rodw.
- phillc54
- Thank you received: 2100
21 Jun 2019 09:21 #137472
by phillc54
I think the configurator is fixed now...
Cheers, Phill.
Cheers, Phill.
21 Jun 2019 09:38 #137476
I just love being the crash dummy. Its a small price to pay for all of your hard work. Just unexpected changes can take some time to understand.
Cheers, Phill.
- phillc54
21 Jun 2019 10:15 #137480
by phillc54
Cheers, Phill.
HaHa, sometimes they take me a while to understand as wellI just love being the crash dummy. Its a small price to pay for all of your hard work. Just unexpected changes can take some time to understand.
Cheers, Phill.
- phillc54
22 Jun 2019 04:12 #137549
by phillc54
I have pushed a couple of enhancements to the configurator:
You can select from a Run tab or a Run panel
The original plasmac.hal is now split into plasmac.hal and plasmac_connection.hal so there is just a link to plasmac.hal rather than a file in your config directory.
It is also possible ti use configurator to overwite an existing config if you need to make any changes. (as always, backup first...)
Cheers, Phill
Cheers, Phill
22 Jun 2019 04:55 #137554
So no change to Plasmac core Phill?
- phillc54
22 Jun 2019 05:01 #137556
by phillc54
No, just the configurator and readme.
- thefabricator03
- Visitor
22 Jun 2019 05:43 #137558
by thefabricator03
Phill,
This might seem like a stupid question,
With the configurator, How do I know what the Hal Pins are for the Arc ok, Ohmic Probe, Ohmic Probe enable, Float switch and Torch on.
With my basic config I have the motors jogging in the basic Axis GUI. but I dont have any of the above in the HAL or INI.
I tried using a HAL file that was posted a while ago with the Plasamc stuff in it but my basic AXIS config would not open saying it cannot find the Plasmac Hal pins.
- phillc54
22 Jun 2019 06:53 #137559
by phillc54
There is no such thing as a stupid question, sometimes there are stupid answers...
You use the HAL pin that you have wired up as that function.
e.g. In my panel I have:
arc-voltage-in = hm2_7i76e.0.encoder.00.velocity
float-switch = hm2_7i76e.0.7i76.0.0.input-08-not
torch-on = hm2_7i76e.0.7i76.0.0.output-00
Cheers, Phill.
Cheers, Phill.
Time to create page: 0.363 seconds
