Another plasma component...
7 years 4 months ago #138266 by mkardasi
Probe time runs continuously on my cfg, even when not running a program. I suppose I am the only one using Safe Height = 0 if that matters.
7 years 4 months ago #138267 by rodw
mkardasi wrote: Probe time runs continuously on my cfg, even when not running a program. I suppose I am the only one using Safe Height = 0 if that matters.
I think what most of us don't understand is the Z axis 0 position should be at the lowest point of travel.
The easiest way to do that is to jog your Z to the top of its, travel, note the absolute coordinates (say its 100mm) then touch off to 100mm
Then your safe height needs to be above the material (say 50mm) and maybe your probe height is say 20mm
7 years 4 months ago #138268 by phillc54
It shouldn't matter where Z0 is.
mkardasi has Safe Height 0 because he has a limited Z travel, this is a new feature introduced a couple of days ago.
I just tried both imperial and metric sims and I cannot see that issue, I will investigate further...
7 years 4 months ago #138275 by mkardasi
Phil, I experimented some more and if I restart Linuxcnc everything is fine. It starts as soon I do a probe. Be it through ngc or hitting the probe test button. Hope this is helpful.
7 years 4 months ago #138277 by phillc54
If you are running from a terminal you should get a PROBE: ON {time} message when probing starts and when a probe is sensed you should get a PROBE: OFF {time} message and the count should stop.
I still haven't been able to duplicate it.
7 years 4 months ago - 7 years 4 months ago #138278 by mkardasi
phillc54 wrote: If you are running from a terminal you should get a PROBE: ON {time} message when probing starts and when a probe is sensed you should get a PROBE: OFF {time} message and the count should stop.
No PROBE: OFF message the counter keeps running until I quit. I've attached my files if that helps you duplicate.
mkardasi@LinuxCNC:~$ cd linuxcnc-dev/src mkardasi@LinuxCNC:~/linuxcnc-dev/src$ source ../scripts/rip-environment mkardasi@LinuxCNC:~/linuxcnc-dev/src$ linuxcnc LINUXCNC - 2.9.0~pre0 Machine configuration directory is '/home/mkardasi/linuxcnc/configs/esab-plasmac' Machine configuration file is 'esab-plasmac.ini' Starting LinuxCNC... twopass:invoked with <> options twopass:found ./esab-plasmac.hal twopass:found ./plasmac.hal twopass:found ./esab-plasmac_connections.hal Note: Using POSIX realtime hm2: loading Mesa HostMot2 driver version 0.15 hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2 hm2_eth: 10.10.10.10: Hardware address: 00:60:1b:16:00:c4 hm2_eth: discovered 7I96 hm2/hm2_7i96.0: Smart Serial Firmware Version 43 hm2/hm2_7i96.0: 51 I/O Pins used: hm2/hm2_7i96.0: IO Pin 000 (TB3-01): IOPort hm2/hm2_7i96.0: IO Pin 001 (TB3-02): IOPort hm2/hm2_7i96.0: IO Pin 002 (TB3-03): IOPort hm2/hm2_7i96.0: IO Pin 003 (TB3-04): IOPort hm2/hm2_7i96.0: IO Pin 004 (TB3-05): IOPort hm2/hm2_7i96.0: IO Pin 005 (TB3-06): IOPort hm2/hm2_7i96.0: IO Pin 006 (TB3-07): IOPort hm2/hm2_7i96.0: IO Pin 007 (TB3-08): IOPort hm2/hm2_7i96.0: IO Pin 008 (TB3-09): IOPort hm2/hm2_7i96.0: IO Pin 009 (TB3-10): IOPort hm2/hm2_7i96.0: IO Pin 010 (TB3-11): IOPort hm2/hm2_7i96.0: IO Pin 011 (TB3-13/TB3-14): SSR #0, pin Out-00 (Output) hm2/hm2_7i96.0: IO Pin 012 (TB3-15/TB3-16): SSR #0, pin Out-01 (Output) hm2/hm2_7i96.0: IO Pin 013 (TB3-17/TB3-18): SSR #0, pin Out-02 (Output) hm2/hm2_7i96.0: IO Pin 014 (TB3-19/TB3-20): SSR #0, pin Out-03 (Output) hm2/hm2_7i96.0: IO Pin 015 (TB3-21/TB3-22): SSR #0, pin Out-04 (Output) hm2/hm2_7i96.0: IO Pin 016 (TB3-23/TB3-24): SSR #0, pin Out-05 (Output) hm2/hm2_7i96.0: IO Pin 017 (TB1-02/TB1-03): StepGen #0, pin Step (Output) hm2/hm2_7i96.0: IO Pin 018 (TB1-04/TB1-05): StepGen #0, pin Direction (Output) hm2/hm2_7i96.0: IO Pin 019 (TB1-08/TB1-09): StepGen #1, pin Step (Output) hm2/hm2_7i96.0: IO Pin 020 (TB1-10/TB1-11): StepGen #1, pin Direction (Output) hm2/hm2_7i96.0: IO Pin 021 (TB1-14/TB1-15): StepGen #2, pin Step (Output) hm2/hm2_7i96.0: IO Pin 022 (TB1-16/TB1-17): StepGen #2, pin Direction (Output) hm2/hm2_7i96.0: IO Pin 023 (TB1-20/TB1-21): StepGen #3, pin Step (Output) hm2/hm2_7i96.0: IO Pin 024 (TB1-22-TB1-23): StepGen #3, pin Direction (Output) hm2/hm2_7i96.0: IO Pin 025 (TB2-01/TB2-03): IOPort hm2/hm2_7i96.0: IO Pin 026 (TB2-04/TB2-05): IOPort hm2/hm2_7i96.0: IO Pin 027 (TB2-07/TB2-08): Encoder #0, pin A (Input) hm2/hm2_7i96.0: IO Pin 028 (TB2-10/TB2-11): Encoder #0, pin B (Input) hm2/hm2_7i96.0: IO Pin 029 (TB2-13/TB2-14): Encoder #0, pin Index (Input) hm2/hm2_7i96.0: IO Pin 030 (TB2-16/TB2-17): IOPort hm2/hm2_7i96.0: IO Pin 031 (TB2-18/TB2-19): IOPort hm2/hm2_7i96.0: IO Pin 032 (internal): IOPort hm2/hm2_7i96.0: IO Pin 033 (internal): SSR #0, pin AC Ref (internal) (Output) hm2/hm2_7i96.0: IO Pin 034 (P1-01): IOPort hm2/hm2_7i96.0: IO Pin 035 (P1-02): IOPort hm2/hm2_7i96.0: IO Pin 036 (P1-03): IOPort hm2/hm2_7i96.0: IO Pin 037 (P1-04): IOPort hm2/hm2_7i96.0: IO Pin 038 (P1-05): IOPort hm2/hm2_7i96.0: IO Pin 039 (P1-06): IOPort hm2/hm2_7i96.0: IO Pin 040 (P1-07): IOPort hm2/hm2_7i96.0: IO Pin 041 (P1-08): IOPort hm2/hm2_7i96.0: IO Pin 042 (P1-09): IOPort hm2/hm2_7i96.0: IO Pin 043 (P1-11): IOPort hm2/hm2_7i96.0: IO Pin 044 (P1-13): IOPort hm2/hm2_7i96.0: IO Pin 045 (P1-15): IOPort hm2/hm2_7i96.0: IO Pin 046 (P1-17): IOPort hm2/hm2_7i96.0: IO Pin 047 (P1-19): IOPort hm2/hm2_7i96.0: IO Pin 048 (P1-21): IOPort hm2/hm2_7i96.0: IO Pin 049 (P1-23): IOPort hm2/hm2_7i96.0: IO Pin 050 (P1-25): IOPort hm2/hm2_7i96.0: registered note: MAXV max: 10.000 units/sec 600.000 units/min note: LJOG max: 10.000 units/sec 600.000 units/min note: LJOG default: 2.500 units/sec 150.000 units/min waiting for s.joints<0>, s.kinematics_type<0> waiting for s.joints<0>, s.kinematics_type<0> waiting for s.joints<0>, s.kinematics_type<0> waiting for s.joints<0>, s.kinematics_type<0> Warning: Forward kinematics must handle duplicate coordinate letters:yy Note: Individual axis homing is not currently supported for KINEMATICS_IDENTITY with duplicate axis letter <Y> note: jog_order='XYZ' note: jog_invert=set([]) task: main loop took 0.153903 seconds PROBE: ON 0.0 task: main loop took 0.148993 seconds task: main loop took 0.141449 seconds Shutting down and cleaning up LinuxCNC... task: 9536 cycles, min=0.000007, max=0.153903, avg=0.010069, 3 latency excursions (> 10x expected cycle time of 0.010000s) hm2_eth: HostMot2 ethernet driver unloaded hm2: unloading Note: Using POSIX realtime mkardasi@LinuxCNC:~/linuxcnc-dev/src$
Last edit: 7 years 4 months ago by mkardasi.
Time to create page: 0.660 seconds
