- Thank you received: 2100
Yes, it should.mkardasi wrote: Page 9 of the User's guide
PID P Gain is listed as used by mode 0. Shouldn't this be modes 0,1?
That was my thought originally as well, but seeing the probing issues have made me rethink (maybe overthink) the way to do it.islander261 wrote: Guys
I am most likely in the minority here. I have not had any probing problems since the middle of May. I find the current probing with rapid to a clearance height and then probe speed to material to work well. I can easily see that results of rapid down coupled with an ohmic or float switch malfunction to cause damage to your torch or the mounting. I am having a hard time seeing how two moves to the material surface will be faster.
I will have to wait until after 8/7 before I can try using PlasmaC from the new master branch.
phillc54 wrote: That was my thought originally as well, but seeing the probing issues have made me rethink (maybe overthink) the way to do it.
I think in the user guide the following line appears three times:Code:WARNING: Probe Height is the height above the minimum Z axis limit.
