- Thank you received: 2100
Well it should go to the top of Z and pause, allowing the operator to determine the cause, it may well have hit a part that has tipped up.To me, the real issue is when the material warps above the probe height and Plasmac can't recover.
It definitely does on my sim and I am sure it did on the test rig but that is pulled apart now.Are you sure it does that and not go into an endless probing loop? Thats what I see here.
then Z goes to the top and the program pausesfloat switch detected while moving to probe height program is paused
ohmic probe detected while moving to probe height program is paused
phillc54 wrote: Well the good news is that the LinuxCNC buildbot now has PlasmaC in the master branch packages and the documents are now online as well, in both HTML and PDF format.
The latest version has an updated Statistics tab with figures per job and totalled plus run time and torch on time were added.
It was my intention to have another crack at it tomorrow but the chief has other ideas...So does this mean you can build your plasma table now?
