- Thank you received: 4153
islander261 wrote: Guys
The ohmic probe tripped while moving is the most common cause I have for stoppage. It is always caused by either water or slag (dross) shorting the nozzle to the shield.
Yes, you need an M67 E3 Q100 (or Q0) to get back to the full feed rate.The first command would read/set the feed rate and the second would change it to 60%. My question is, what will that third command do? Will it reset back to the original feed rate or will it be essentially ignored? When I read the documentation, I'm led to believe that you have to do an M67 E3 Q100 to get back to the original feed rate.
With my old CandCNC feather touch ohmic probe I did not have these problems given the exact same running conditions,
I am not that great with electronics but I have read something in the past that said the big manufactures have a way to set the sensitivity of the Ohmic probe circuit, How would something like that work for our setup?
phillc54 wrote: Is the feather touch a separate piece of hardware?
Does it have a "sensitivity" adjustment?thefabricator03 wrote: Yeah its a small box that houses the ohmic sensing electronics, It is usually mounted on the Z axis.
