- Thank you received: 25
If Fusion 360 has a tool table in text format I could have a look at adding that to the material file converter.docwelch wrote: Excellent. That's the behavior I was hoping for and what I had understood from the documentation. I think I have a pretty decent way to do this now. I'll post a link here and start a new thread on the plasmac post processor for Fusion 360 once I get a little further along. I know a lot of you are using Sheetcam and it seems to be a good product - I just have a lot of experience using Fusion 360 already (CNC routing, 3d printing) so want to stick with it if I can.
Steven
Yes, I have just seen a couple of others.rodw wrote: Yes
www.candcnc.net/store-home/feather-touch-ohmic-sensor/
I think other systems have a sensitivity setting (eg a pot.) I wonder if we could use a Mesa analog input somehow as part of this?
docwelch wrote: Phill,
It does have a tool table. I think plasmac will require something a little different but I did find this Fusion 360 tool table to LinuxCNC . I don’t have an extensive tool table built for plasma cutting at this time but I can send what I have to you for testing if you want.
Guys,
I understand the reasoning behind the material table for plasmac and its relationship to the tool table in the CAM program. Are there any situations where you change the tool/material in a single g code file?
Steven
