- Thank you received: 2100
If you can send a tool table that was exported directly from Fusion360 that would be good.I don’t have an extensive tool table built for plasma cutting at this time but I can send what I have to you for testing if you want.
phillc54 wrote: Does it have a "sensitivity" adjustment?
Would it be possible to wire it into your current config?
That sounds feasible but beyond my capabilities.So would it be possible to add a variable sense impedance and filtering circuit to our open source ohmic circuit?
rodw wrote: Yes
www.candcnc.net/store-home/feather-touch-ohmic-sensor/
I think other systems have a sensitivity setting (eg a pot.) I wonder if we could use a Mesa analog input somehow as part of this?
PCW wrote:
In the mean time, it might be worth testing a bit with a Ohmic sensor
based on a THCAD and a floating 24 to 100V or so power supply.
(maybe some 9V batteries to guarantee floating and high isolation)
I can donate a THCAD If someone wants to try this. if nothing else
it would be interesting to see if leakage can be distinguished from
contact by getting real time resistance information.
PCW wrote: In the mean time, it might be worth testing a bit with a Ohmic sensor
Beware that everything on the torch side including Ohmic sensing connections
can be at lethal potentials so this is not something to be undertaken lightly
