Another plasma component...
7 years 3 months ago #139533 by docwelch
Replied by docwelch on topic Another plasma component...
Thanks, I'll download it and see how my output compares to what is in the repository.
Steven
7 years 3 months ago #139547 by phillc54
Steven,
Attached is the preliminary converter file if you would like to give it a try.
I have used the tab limited version.
I have assumed that the original units are either metric or imperial so no conversion should be necessary, it seems SheetCam store all units as metric equivalents.
It will ask for the unknown parameters for each 'tool' as it loops through the file. The last entered parameters will be used as the default for the current tool.
The following user(s) said Thank You: docwelch
  • thefabricator03
  • Visitor
  • Visitor
7 years 3 months ago #139658 by thefabricator03
Replied by thefabricator03 on topic Another plasma component...
Phill,
Have you pushed any updates lately,
I did a git pull and could not see a disable box for the ohmic, are we still going to put that in?
Dont get me wrong I am not complaining just wondering if that feature request will make it in.
  • thefabricator03
  • Visitor
  • Visitor
7 years 3 months ago - 7 years 3 months ago #139659 by thefabricator03
Also the disable G-code feature is working well,
I have gotten my Sheetcam cut rules sorted and now am using the turn off g-code feature on my holes and towards the end of the cut, That has fully eliminated the torch diving when it is performing a overcut.
Last edit: 7 years 3 months ago by thefabricator03.
7 years 3 months ago - 7 years 3 months ago #139660 by phillc54
thefabricator03 wrote: Phill,
Ohmic Enable should be a check box on the Config tab.
Edit: maybe that would actually be better on the Run tab???
Last edit: 7 years 3 months ago by phillc54.
  • thefabricator03
  • Visitor
  • Visitor
7 years 3 months ago #139665 by thefabricator03
Run tab would be good.
Time to create page: 1.175 seconds
