- Thank you received: 2100
Another plasma component...
- phillc54
7 years 3 months ago #139666
by phillc54
Did you find it in your config?
- thefabricator03
- Visitor
7 years 3 months ago #139667
by thefabricator03
No I did not, I must of done something wrong with the git pull,
I am halfway though a sheet, ill try again this afternoon.
Replied by thefabricator03 on topic Another plasma component...
phillc54 wrote: Did you find it in your config?
- thefabricator03
- Visitor
7 years 3 months ago #139671
by thefabricator03
Anther sheet cut by PlasmaC,
Dont let anyone tell you that 16mm sheet does not need THC, On these longer cuts THC works very well,
- phillc54
7 years 3 months ago #139672
by phillc54
I have just pushed an update:
1. Move ohmic probe enable to the Run tab/panel
2. Add Fusion 360 conversion and ability to manually build a material file using materialverter (that really is a horrible name)
3. Fix embedded tab error in Axis
The following user(s) said Thank You: tommylight, Grotius, thefabricator03
- thefabricator03
- Visitor
7 years 3 months ago #139758
by thefabricator03
Just updated my config, Ohmic disable is working well.
When I first tried to update I did not read the message properly and it said that the git pull had been aborted.
I looked into it and it did not want to override my local changes, I had to make some changes to the python files because when my CandCNC controller failed something must of happened to my arc OK relay on the plasma unit. I have to use the softwares soft arc ok setting.
With my big machine I had to set the high voltage limit to 250 from 200, It took me a while to figure out but when I made the changes it has not failed.
- phillc54
7 years 3 months ago - 7 years 3 months ago #139759
by phillc54
Thanks for the report.
Actually it would be good if any guys who are using the soft arc ok (Mode 0) could let me know their OK High Volts and OK Low Volts and I could put something in the docs as a starting point for new installs.
Edit: Machine type would be good as well.
I like the pics of yesterdays sheet, I must say the 16mm sheet distorted more than I thought it would.
Last edit: 7 years 3 months ago by phillc54.
Time to create page: 0.990 seconds
