Another plasma component...
7 years 3 months ago #140129 by docwelch
Replied by docwelch on topic Another plasma component...
Phill,
I figured out how to extend an arc by 4mm when a full circle is cut. I have it programmed but ran into 2 issues:
  1. If I am trying to turn off the torch with M62, what P value is used?
  2. If we turn off the torch with this command, is it going to cause plasmac to stop thinking there is an error? I know there is an arc lost error and am concerned this action might trigger that error even though we are doing it on purpose. Can we suspend checking for arc lost for this one move since we have commanded the arc to turn off?
I've attached the new plasmac_gcode_arcs.py file for your perusal. It has all the changes that were in the file in my last post plus these new changes. You'll see on line 237 my question mark regarding the M62 P value.
Steven
7 years 3 months ago #140131 by phillc54
docwelch wrote: Phill,
Because our discussion has turned back to plasmac and away from post-processors, I thought I would move us back to this thread. I've added code to adjust the kerf. Without some real kerf width vs. speed data, it's hard to know if this is really useful or complete overkill. Anyway, here it is. I stayed with your pattern of adjusting all arcs below a certain radius, not just circles.
This will only work with compensated code (no G41.1 or G42.1). I think I could get it to work with uncompensated code but it will require a little more thinking.
There are a couple of other things that Jim Colt writes about improving hole quality - start the lead in at the middle of the hole (maybe easier to set this up in the post-processor than in plasmac) and have the torch turn off exactly where the hole started while still moving (basically continue the arc a little further). I'll see if I can figure out how to do one or both of these. My thinking is that putting these things in plasmac makes a lot of sense as they are clearly plasma specific.
Steven
I think that with the amount of variables that affect kerf width it is a bit too much to expect for a gcode parser. This should all be handled by the post processor.
7 years 3 months ago #140132 by phillc54
PlasmaC uses M5 to turn the torch off
Not applicable as you cannot turn the torch off
7 years 3 months ago - 7 years 3 months ago #140133 by rodw
its not the torch that gets turned off with the M62, Its the THC. If we get the void sensing sorted, it won't be necessary. Its this hole cutting I think where the void sensing will have the most value.
Last edit: 7 years 3 months ago by rodw.
7 years 3 months ago #140136 by phillc54
I am contemplating moving the following spin boxes from the Run tab/panel to the Config tab.
Does this cause problems for anyone???
THC Delay
THC Threshold (V)
THC Speed
Corner Lock Threshold (%)
Kerf Crossing Override (%)
I am guessing that these parameters once set would not be changed too much.
7 years 3 months ago #140137 by docwelch
I understand your concerns - the complexity quickly rises.
Using M5 to turn off the torch certainly will work. I had thought there was probably a digital pin we could reference from M62 to do the same thing. Cannot remember where it was but I saw someone using that command in their gcode.
I don't think changing the locations of the spin boxes would be a problem.
Steven
Time to create page: 0.374 seconds
