Another plasma component...
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
26 Jul 2019 22:46 #140695 by phillc54
I was thinking of adding a torch off via a digital pin for 'overburn' of whatever it is called.
26 Jul 2019 22:49 #140696 by Grotius
Replied by Grotius on topic Another plasma component...
Phill,
Do you mean ignition time out?
  • thefabricator03
  • thefabricator03's Avatar
  • Visitor
  • Visitor
27 Jul 2019 02:09 #140709 by thefabricator03
Replied by thefabricator03 on topic Another plasma component...
Phill,
Changing the delay setting to 0.1 fixed the problem,
But as Franklin wrote should the delay be before the z axis raises up? That would make the feature work like it should in my option.
  • phillc54
  • Platinum Member
  • Platinum Member
27 Jul 2019 02:49 - 27 Jul 2019 02:55 #140710 by phillc54
I am not sure, this is where plasma cutting seems to have a real problem, it depends on where you read something as to what something is named...
What I mean is turn the torch off at the end of hole (which was also the start of the hole) so X/Y can continue for about 4mm before the Z axis raises.
Edit: Number 3 on this page
So when we get a M5, turn torch off (if not already off), stop for n seconds then raise the Z axis.
I have a good project for someone: ;)
Come up with a set of naming conventions for LinuxCNC so at least we know we are all talking about the same thing.
Last edit: 27 Jul 2019 02:55 by phillc54.
The following user(s) said Thank You: tommylight, thefabricator03
27 Jul 2019 03:11 #140711 by rodw
Phill, once you get this finalised, the Plasmac GUI and docs will be the gold standard plasma dictionary!
Yes any delays should keep the torch at cutting height until its over otherwise there is no point keeping the arc running. The intent is to let the trailing arc on the lower side catch up to the end point.
I'm wondering if it should not be able to be changed with M67/M68 from gcode? Different materials and different cut types (holes vs outside cuts might need different delays.
What does Stefan think ? I'm not really the one to make a call on that.
  • thefabricator03
  • Visitor
  • Visitor
27 Jul 2019 03:57 - 27 Jul 2019 04:00 #140714 by thefabricator03
I do not think we need different delays for different cut types, Unless we are going to turn PlasmaC into sheetcam! If we were to do that then that would help. I over cut my holes and outside cuts. Just makes it easier to pull the finished part out of the skeleton and get the center slugs out of holes.
I feel that just having the delay work as it should by leaving the z axis at cut height until the torch has finished will solve 98% of all problems.
Dont worry Phill, with all of the testing I am doing with your baby we will have it at a industrial level in no time! I am averaging about 2 full sized sheets a day, thicknesses from 1.6mm up to 25mm and everything in between. Also cutting small parts and very large parts.
One thing that is out of this scope of this project and even physics I think would be if we could eliminate taper of air plasma parts. That would truly be something worth working towards if possible! Looks like a Hi Definition unit is in my future. Problem is they start at the $40,000 price range.
90% of the parts I cut dont need to be perfectly square edges but for the other 10% having the part come out with square edges would save a bit of grinding.
Last edit: 27 Jul 2019 04:00 by thefabricator03.
27 Jul 2019 07:46 #140722 by robertspark
Replied by robertspark on topic Another plasma component...
do need to use a standard nomenclature though
27 Jul 2019 07:53 #140723 by robertspark
how are you controlling the torch off before the end of the overcut?
I presume that the overcut is set in sheetcam??
how do you tell the torch to turn off early? (I use the equivelent of m63 Px)
  • thefabricator03
  • Visitor
  • Visitor
27 Jul 2019 08:11 #140724 by thefabricator03
With the G-code I dont program manually, I use Sheetcam for the code generation, I set the overcut in the sheetcam cut settings.
27 Jul 2019 08:13 #140725 by robertspark
how do you tell the torch to turn off early? (I use the equivelent of m63 Px)[/quote
but how does linuxcnc know when to turn off the torch early before M5? (before the overcut)
Time to create page: 0.246 seconds
