Another plasma component...
7 years 2 months ago #141456 by EW_CNC
Replied by EW_CNC on topic Another plasma component...
Just a guess but the name of material18 has a space and is the longest so far
I found the problem, material 18 edge pierce was the first material that had a missing parameter, pierce height and peirce delay were blank.
Thanks,
E.W.
7 years 2 months ago #141459 by phillc54
Thanks,
E.W.
Thanks for the report, it looks like I should add some sort of error checking.
7 years 2 months ago #141460 by phillc54
Grotius wrote: Rodw,
I have read the overcut depend's on enabling factor 2. But i see not how the overcut is done.
It looks a impossible job to me that linucnc can do a overcut for all contour's at this moment. Linuxcnc is not a cam package and
has almost no logic about cam on board.
It is done by the GCode parser and only does full circles at this stage.
  • thefabricator03
  • Visitor
  • Visitor
7 years 2 months ago #141483 by thefabricator03
Replied by thefabricator03 on topic Another plasma component...
Phill,
Just did a Git Pull and I get the following error message when I try to open a gcode file,
Attachment not found
7 years 2 months ago #141484 by phillc54
Yes, I found that today but haven't pushed the fix yet.
If you use the code I posted for you to try here it will fix it as well.
If you just want a quick fix change line 279 of plasmac_gcode.py
a,b = line.strip().split('(')
to:
a,b = line.strip().split('(', 1)
  • thefabricator03
  • Visitor
  • Visitor
7 years 2 months ago #141485 by thefabricator03
Perfect, Thanks Phill
Time to create page: 1.914 seconds
