- Thank you received: 2100
Another plasma component...
- thefabricator03
- Visitor
7 years 2 months ago #141569
by thefabricator03
Ok thats sorted now, And yeah that would help if you could make that change for future revisions,
Still having the problem with the G-code file tho, I haven't been able to manually edit the g-code since I cannot find the * symbol anywhere in the code.
Replied by thefabricator03 on topic Another plasma component...
phillc54 wrote: I could probably default THC, Puddle Jump Height, Puddle Jump Delay and Cut Amps to 0 if there is no entry but the others need to be there.
- phillc54
7 years 2 months ago #141571
by phillc54
The * is referring to the * in the GCode display of the second pic you posted.
That is there because it cannot find material number 2121 which of course doesn't exist...
For some reason it seems it is reading line 11 of you code incorrectly.
Edit line 11 so there is no comment, just M190 P21.
Actually that format looks like you are not using the recent version of plasmac_gcode.py.
- thefabricator03
- Visitor
7 years 2 months ago - 7 years 2 months ago #141572
by thefabricator03
When I do a git pull it says its up to date.
That would rule out not using the latest version?
Also I am using Rod post processor he posted and I have set the Sheetcam code snippets as per his recommendations.
Last edit: 7 years 2 months ago by thefabricator03.
- phillc54
7 years 2 months ago #141573
by phillc54
OK, I can replicate that here so it is another cockup by me.
Edit your ngc file so there are no comments after a M190 and you should be able to get back to work.
I will take a look now and fix it.
Sorry...
Sorry...
- thefabricator03
- Visitor
7 years 2 months ago #141575
by thefabricator03
Lol new problem,
Edited the G-code and get this error,
Dont worry we will get there eventually
- phillc54
7 years 2 months ago #141576
by phillc54
Try this:
Edit plasmac_gcode.py so it looks like:
200 if 'm190' in line:
201 if '(' in line:
202 line = line.split('(', 1)[0]
203 elif ';' in line:
204 line = line.split(';', 1)[0]
204 first, last = line.split('p', 1)
Time to create page: 2.311 seconds
