- Thank you received: 2100
Another plasma component...
- thefabricator03
- Visitor
7 years 2 months ago #141515
by thefabricator03
I am using a post processor posted by John in this thread a while ago,
I have the sheetcam rules set as per this picture,
I will check that file out tomorrow as the machine is cutting at the moment.
Replied by thefabricator03 on topic Another plasma component...
phillc54 wrote: I don't see any M67 codes in the file to reduce the feed rate.
- phillc54
7 years 2 months ago - 7 years 2 months ago #141516
by phillc54
OK, I also ran that ngc file with #<pierce-only = 1 and it seemed to work as well, 364 pierces...
EDIT: I just noticed your code says DHTC-OFF, should that be something else? I know nothing about SheetCam
Last edit: 7 years 2 months ago by phillc54.
- thefabricator03
- Visitor
7 years 2 months ago #141517
by thefabricator03
No, DTHC-OFF is telling the controller to turn off the digital torch height control for the hole.
So it must be something in the Post processor that is causing it to not output M67 feed-rate code? Or could it be that it was never set up to do that in the first place. Just thinking about it and all of the parts I have cut up until this point I did not need decent holes so I must not of noticed it.
- phillc54
7 years 2 months ago #141518
by phillc54
Sorry I can't help with that, but it may have had something to do with the problem you mentioned about some holes earlier on.
Hopefully Rod or John will chime in.
- Thank you received: 4153
7 years 2 months ago #141539
Stefan, Can you try the post processor I shared here:
forum.linuxcnc.org/plasma-laser/36568-po...smac?start=80#139099
I don't think I made any changes since.
The following user(s) said Thank You: Grotius, thefabricator03
- islander261
- Thank you received: 216
7 years 2 months ago - 7 years 2 months ago #141545
by islander261
Replied by islander261 on topic Another plasma component...
Phill
I installed the latest master branch (RIP) yesterday and have encountered a couple of new features that are causing me problems.
1. When I change the material from Gcode the program pauses every time. The optional pause on M1 is set to off on the GUI. This is not good when you have several materials per part and a whole sheet of parts. On further testing this maybe a Gmoccapy 3.0.X problem because it occurs regardless of the state of the optional pause button on the GUI.
2. The Gcode parser is adding an extra ) at the end of the last comment in the file. This is causing a loading error the requires editing the file using the built in editor to remove the extra ) and saving the file. Again usable but a PITA. The removal of spaces and forcing lower case in comments makes reading difficult for old guys.
Please find attached a file that cause both to happen.
Update
Issue 1 is normal behavior for Gmoccapy 3.0.7.1 so I fixed my PP so it will not post M1 optional stops. Issue 2 was fixed by downloading and updating new files this afternoon.
Update
Last edit: 7 years 2 months ago by islander261. Reason: Update
Time to create page: 0.786 seconds
