- Thank you received: 2100
Another plasma component...
- thefabricator03
- Visitor
7 years 2 months ago #141954
by thefabricator03
Replied by thefabricator03 on topic Another plasma component...
Phill,
What is the easiest way to change PlasmaC configs?
I need to change from the synthetic arc ok signal to a real signal, My loan plasma has turned up and I need to swap the setup over.
- phillc54
7 years 2 months ago #141961
by phillc54
If you set it up with the configurator you can edit your ini file to change the mode to 1 and edit your plasmac_connections.hal to connect your arc ok signal to the appropriate HAL pin.
- phillc54
7 years 2 months ago #142109
by phillc54
I have pushed an update:
Fix program end bug in GCode parser.
Set defaults for optional variables in the materialverter.
Add the ability for the configurator to
modify
Operating Mode, HAL pins and Run Panel position of a working configuration.
The following user(s) said Thank You: tommylight, Clive S, thefabricator03
- Dee436
- Thank you received: 13
7 years 2 months ago #142171
by Dee436
Replied by Dee436 on topic Another plasma component...
I am currently on a run in place version of plasmac from around May which uses v2.8. The machine is working and cutting ok but I am thinking I should really bring it up to date, I have had a couple of instances where the paused motion would have been useful. I really don’t want to break anything though so have a couple of questions.
If I do a git pull upgrade to get the latest version;
Am I likely to encounter any problems with such a large jump in versions?
Will I need to run the configurator, the manual says not usually which suggests sometime you may need to?
Will I need to alter the directory structure as I seem to recall it changed at some point?
I assume after running the upgrade I will be on v2.9 master and have the paused motion available?
If there is any chance of messing up my working table I will wait until I know I have time to sort it out, on the other hand if it is going to be a non issue I will go ahead and get up to date
- phillc54
7 years 2 months ago #142173
by phillc54
If you used the configurator to do your original installation then it "should" be safe to pull the latest and then run configurator to upgrade your config.
Another option if you originally used the configurator would be to pull the latest and create a new config with the configurator using the backup ini and Hal files in your existing config that were created by the configurator.
You will need to run make after pulling the latest version.
Don't forget to make a backup of your existing config before attempting an update.
- Thank you received: 4153
7 years 2 months ago #142175
Dee
I upgraded my 2.9 config the other day. It sounds like you installed from Phill's repository which no longer exists. If so, I would install into another folder linuxcnc-dev and install into there from scratch as per
linuxcnc.org/docs/devel/html/code/building-linuxcnc.html
Just make sure you run the correct rip-environmment script and it should all work the same.
Time to create page: 0.417 seconds
