Another plasma component...
7 years 2 months ago #142201 by Dee436
Replied by Dee436 on topic Another plasma component...
My version is prior to the configurator been available and I wasn’t aware Phil’s repository no longer existed. I will go with Rod’s option of compiling another run in place alongside my existing one. A job for the weekend I think
Thanks all
7 years 2 months ago #142202 by phillc54
Dee436 wrote: My version is prior to the configurator been available and I wasn’t aware Phil’s repository no longer existed. I will go with Rod’s option of compiling another run in place alongside my existing one. A job for the weekend I think
That is the best option if you didn't use the configurator.
To use the configurator you need an ini file without any of the PlasmaC items and a HAL file the same. The configurator will also copy them into the new config directory as backups.
7 years 2 months ago #142206 by rodw
Thanks all
I'm glad I read that right (That you had compiled from Phill's repository). It will only take you a couple of minutes (and a coffee)
  • thefabricator03
  • Visitor
  • Visitor
7 years 2 months ago #142297 by thefabricator03
Replied by thefabricator03 on topic Another plasma component...
So I had a chance to use Phills pierce only function,
This was the straw that broke the camels back, Slag from the hole piecing tripping the torch when it was cutting the outside of the plate
So I generated my g-code as normal in sheetcam but I added this line of code to the start of the files,
#<pierce-only> = 1
That produced a piece only g-code files,
The result looks like this,
After cleaning it looks like this,
I am still cutting the sheet out now but have not had any issues with slag tripping the torch! Works as advertised!
7 years 2 months ago #142308 by rodw
Wow! how many commercial plasma controllers do that!
The following user(s) said Thank You: tommylight, thefabricator03
  • thefabricator03
  • Visitor
  • Visitor
7 years 2 months ago #142351 by thefabricator03
Phill,
Is it possible for PlasmaC to be able to insert the code #<pierce-only> = 1 into a loaded g-code file and have a button in the interface so we can toggle it on when we want to us the pierce only function?
Time to create page: 0.686 seconds
