Another plasma component...
  • thefabricator03
  • Visitor
  • Visitor
7 years 2 months ago #142474 by thefabricator03
Replied by thefabricator03 on topic Another plasma component...
Dee436 wrote: Yes the files I have posted are from my working earlier configuration. If you could edit them that would be great as I am a bit lost as to what to change.
Darren
If I were in your situation I would save your config files and start fresh.
Just use the configurator to set up you hal signals and be done with it. You will be up and running quicker.
7 years 2 months ago #142475 by phillc54
Darren,
Hopefully these will get you going.
Put them any where on your machine, run the configurator in New mode as these two files will be your base machine.
linuxcnc.org/docs/devel/html/plasma/plas...smac_to_base_machine
Select Mode 1
Give the new machine a name
Enter the following into the appropriate fields
arc voltage = hm2_5i25.0.encoder.00.velocity
arc ok = hm2_5i25.0.7i76.0.0.input-06
float switch = hm2_5i25.0.7i76.0.0.input-04-not
torch = hm2_5i25.0.7i76.0.0.spinena
On the fist run, set any appropriate values in the Config panel and you should be good to go.
I took the liberty of removing the arc voltage scaling and off set from your HAL file as it can be done in the Config Panel of a PlasmaC config.
Voltage Scale = 0.01313928
Voltage Offset = -48
The following user(s) said Thank You: Dee436
7 years 2 months ago #142476 by Dee436
Replied by Dee436 on topic Another plasma component...
Hi Phill
I will be in the workshop again in a few hours so will try the files and configurator.
Thank you for taking the time to help me again.
Darren
7 years 2 months ago - 7 years 2 months ago #142496 by Dee436
Spent quite a lot of time on this today.
I eventually commented out the air scribe in the hal file and changed spindles from 2 to 1 in the traj section of the ini file and got it to start up properly. I am now at a point where I can home and jog etc.
I still have a couple of issues though. My arc voltage is stuck at 49 and changing the offset does not make any difference. With the previous setup it registered 0 when not cutting.
Also
When trying to load any gcode I get an error message that’s prevented me being able to make any cuts to see if everything else works.
I have attached a photo that shows the static voltage reading (torch off nothing happening) and the error I receive when loading gcode programs.
Darren
Last edit: 7 years 2 months ago by Dee436. Reason: Grammar
7 years 2 months ago - 7 years 2 months ago #142519 by phillc54
Sorry Darren, I have created a problem...
I pushed an update but Gmoccapy is not ready for it, only Axis.
Due to prior commitments I am unable to help out for a day or two.
[strike]If you go to your repo clone and run git reset --hard HEAD^, this should remove the commit then you can run make again and see how that goes. Failing that you will need to go back to your old config until I sort it out.
[/strike]
EDIT:
An easier option may be to edit plasmac_gcode.py and change line 48 to cutType = 0.
Last edit: 7 years 2 months ago by phillc54.
7 years 2 months ago - 7 years 2 months ago #142520 by phillc54
[strike]For all Gmoccapy users, please don't update until further notice. I have made a boo boo that needs repairing.[/strike] :(
Temporary fix pushed.
Time to create page: 0.264 seconds
