Another plasma component...
- thefabricator03
- Visitor
21 Aug 2019 07:05 #142695
by thefabricator03
Replied by thefabricator03 on topic Another plasma component...
With the air scribe,
I cannot find setp plasmac.multi-tool 0 in my <MACHINE_NAME>_connections.hal.
I have posted the file to this post.
- Dee436
- Thank you received: 13
21 Aug 2019 07:06 #142696
by Dee436
Hi Phill
I will make the hostmot edit and change the spindles back to 2 and see what happens
Darren
Replied by Dee436 on topic Another plasma component...
Darren,
In hindsight, I think this issue is why you had to set SPINDLES = 1 in the TRAJ section of the HAL file and had problems with the air-scribe part of connections.hal
Hi Phill
Darren
- phillc54
- Thank you received: 2100
21 Aug 2019 07:13 #142697
by phillc54
Sorry Guys,
It looks like the issue is causing the Configurator to quit without finishing and causing a bit of havoc...
Try these files Stefan.
- thefabricator03
- Visitor
21 Aug 2019 07:18 #142698
by thefabricator03
The load sheet button, I have never used it.
Which button do you want to change to the Pierce option?
- phillc54
21 Aug 2019 07:21 #142699
by phillc54
Try this...
- thefabricator03
- Visitor
21 Aug 2019 07:37 #142701
by thefabricator03
That worked now just getting the tool table setup
- thefabricator03
- Visitor
21 Aug 2019 07:59 #142702
by thefabricator03
Ok with the scribe,
The sheetcam file you sent me, The torch is being used when I have run the code instead of the scribe.
If I manually run M3 $1 S0, I can not longer jog the machine but then when I run the program the machine starts moving again and the torch goes to cut out the scribed part.
- thefabricator03
- Visitor
21 Aug 2019 08:01 #142703
by thefabricator03
Its not changing the program when I press the button to pierce only.
Try this...
- phillc54
21 Aug 2019 08:08 - 21 Aug 2019 08:25 #142704
by phillc54
YES, that is from the temporary fix I pushed yesterday morning. I am almost done and will push an update that should fix everything soon.
Last edit: 21 Aug 2019 08:25 by phillc54. Reason: remove redundant comments...
- phillc54
21 Aug 2019 08:23 - 21 Aug 2019 10:35 #142706
by phillc54
I have pushed an update which should fix all the latest issues that I caused.
Edit: I haven't done any docs for the Pierce Only mode yet.
Edit 2: Now I have ...
I also have the user guide in PDF format for downloading.
Last edit: 21 Aug 2019 10:35 by phillc54.
Time to create page: 0.349 seconds
