Another plasma component...
  • thefabricator03
  • thefabricator03's Avatar
  • Visitor
  • Visitor
21 Aug 2019 21:21 #142743 by thefabricator03
Replied by thefabricator03 on topic Another plasma component...
Phill,
With the scribe, Your update has gotten everything working. kinda..
When I run the sheetcam job file you sent me, If I do not run the M3 $1 S1 before starting the program the torch will try to cut out the air scribe part. Then when I do run the command it will try to scribe the first P and the next letter it goes back to using the torch.
Is that because as the scribe retracts it is turning the change spindle code off? Maybe we need to link the arm scribe function to something else rather that the spindle off and on command. Just a thought, I am still very inexperienced with G-code.
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
21 Aug 2019 22:24 #142746 by phillc54
I have kinda messed things up over the last couple of days. Have you updated again since about 6:30pm yesterday.
Could you post your INI file, your machine HAL file and your connections HAL file.
It may be worthwhile you doing what I suggest to @MakingStuff here .
  • thefabricator03
  • Visitor
  • Visitor
21 Aug 2019 22:29 #142747 by thefabricator03
I last updated at 6:30am this morning,
I have attached the requested file to his post.
  • thefabricator03
  • Visitor
  • Visitor
21 Aug 2019 22:34 #142748 by thefabricator03
And dont be so hard on yourself Phill,
You need to break a few eggs to make a omelette,
You should of seen my list of fuck ups when I first built my machine!
  • phillc54
  • Platinum Member
  • Platinum Member
22 Aug 2019 01:06 - 22 Aug 2019 01:07 #142750 by phillc54
Is that plasmac.ngc with the four holes and the word PlasmaC?
I am at a loss, I just did a clone and rip build, ran Configurator and loaded plasmac.ngc and it worked as it should.
There should be no need to do M3 $1 S1 before a program is run, that should be taken care of by the program.
The only thing I can see I need to do is stop an M3 S1 turning on the air scribe as well as starting a cut but that is a separate issue
Can you confirm that the GCode in the window after loading the program is the same as pic I have posted here.
Last edit: 22 Aug 2019 01:07 by phillc54.
  • thefabricator03
  • Visitor
  • Visitor
22 Aug 2019 01:11 #142751 by thefabricator03
I just generated the G-code from that file and ran it.
Ive attached the NGC file to this post.
  • thefabricator03
  • Visitor
  • Visitor
22 Aug 2019 01:13 #142752 by thefabricator03
If you can send me the g-code file you are using I will test it, It might be a problem on my end.
  • phillc54
  • Platinum Member
  • Platinum Member
22 Aug 2019 01:17 #142753 by phillc54
Yes, the file you are using is only generating M3 S1 codes.
Also I see that you still have the Manual tool change component loading, that is a consequence of my errors in the Configurator.
Try this HAL file as well.
  • thefabricator03
  • Visitor
  • Visitor
22 Aug 2019 02:03 #142758 by thefabricator03
That got it working,
How can I set up that I want the scribe to come down then start the scriber then move after the scribe has started.
I want to have the scribe activated for a certain number of seconds before motion.
  • phillc54
  • Platinum Member
  • Platinum Member
22 Aug 2019 02:06 #142759 by phillc54
So you want:
  1. scribe arm output activates
  2. adjustable delay
  3. scribe start output activates
  4. adjustable delay
  5. motion begins
Time to create page: 0.303 seconds
