- Thank you received: 4153
Another plasma component...
7 years 6 months ago #131914
Phill,
IDEA TIME: When you are next touching your Python code, could you add a ToolID field to your materials file? No need to display it but maybe auto add it starting at 1 in the python structure if its not in the materials file to support existing configs?
I was having a look at the Toolchange docs . I think if you did this, it would be very easy to select the material from Gcode with a Tnn M6.
Plasmac would need to receive a pin from iocontrol and set another pin once the correct material is selected.
In a sheetcam environment, the only variable that needs to be sent to the post processor would be the ToolID for the Tnn M6
Would be very cool....
- phillc54
- Thank you received: 2100
7 years 6 months ago #131916
by phillc54
Rod,
That would not be too hard, I will post a more detailed response when I get back to a real keyboard.
Cheers, Phill.
Cheers, Phill.
7 years 6 months ago #131917
Thats what I thought so I'll wait patiently.
phillc54 wrote: Rod,
Cheers, Phill.
- islander261
- Thank you received: 216
7 years 6 months ago #131921
by islander261
Replied by islander261 on topic Another plasma component...
Phill
I have often wondered why the plasma world doesn't handle cutting parameters this way. I think this is going back to the Mach legacy and a fixed tool table structure.
7 years 6 months ago #131924
John, I tried your post thinking it might be better than mine but I could not spot holes so it looks like I have to clean mine up
Also for Phill when he gets to updating the tool table, how can plasmac cut accurate engineering parts if it does not have a kerf width to set the tool offset? I just noticed that. We'll have to think of a way to do that.
I have to say some of my yoyo problems are confined to earlier versions of Plasmac. I've now deleted some obsolete configs....:woohoo:
Here was today's job cutting 1.6mm Aluminium at about 5000 mm/min,
This impressive as it shows the THC coping well with my uneven table as on the dry run, the torch hit the sheet and paused.
- islander261
7 years 6 months ago - 7 years 6 months ago #131958
by islander261
Rod
Sorry my post doesn't have drilling support because I don't need it, easy to put back in.
Right now I use my PP to compensate for kerf width as I think most do. You are right on target with suggesting putting kerf width (tool diameter) into the tool table and using G40-G42 to control the part cut side of the cut. Moves Plasmac closer to a generic CNC application.
Last edit: 7 years 6 months ago by islander261.
Time to create page: 1.743 seconds
