Another plasma component...
  • thefabricator03
  • Visitor
  • Visitor
7 years 6 months ago #132085 by thefabricator03
Replied by thefabricator03 on topic Another plasma component...
I got a quote a couple of years back for the Hypertherm Pronest software and the basic package cost upwards of $10,000 AUD and the flagship version was going to cost 30,000 AUD.
For what you can do value wise with Sheetcam there is nothing that comes close for the money.
7 years 6 months ago - 7 years 6 months ago #132125 by rodw
PLASMAC Tn M6 toolchanger:
I've not tried this but it should work. The plasmac materials file needs three extra entries in it:
ToolID = Unique numeric number representing LinuxCNC's Tool Table Tool Number
KerfWidth = the width of the kerf (Tool Table tool diameter)
Thickness = the material thickness (in device units)
So when the machine is homed (eg when joint.X.homed, joint.Y.homed and joint.Z.homed have all transitioned to a true state),
Plasmac should loop through the Materials table and issue a
G10 L10 P[ToolID] Z [Thickness] R[KerfWidth]
for each material.
This will write out a tool table to the Plasmac settings
See: linuxcnc.org/docs/devel/html/gcode/g-code.html#gcode:g10-l10
So a Post processor (like sheetcam) just needs to know the ToolId for each material in the plasmac .mat file and issue an appropriate
Tn M6
and subsequently issue the appropriate G41/G42 command for inside and outside cuts before each M3 (And a G40 when done)
Adding the Z offset should compensate for material thickness so the probe height will always the same height above the material when changing from say 16mm to 1.6mm material.
If this can be done it would be waaay cool and as close as you can get to not having data redundancy (eg duplicate settings) other than in the post processor.
Finally plasmac could generate a sheetcam tool table which the user could import into sheetcam. This would truly make plasmac the single point of truth for all settings. Nobody has been able to achieve that with entry level plasma THC systems......
Last edit: 7 years 6 months ago by rodw.
7 years 6 months ago #132131 by islander261
Replied by islander261 on topic Another plasma component...
Rod
You are correct that this is testing that needs to be done. Plasmac is really close to being a little giant killer right now. Adding the tool management will push all other applications less than the HT integrated systems to the Mach ancient history heap.
I am sure that Phill has the skills to pull this off given what he has produced so far. We need to cheer him on to get his system running to move this beyond theory for him.
I have hacked in external control of the THC enable from Gcode which I hope makes it back into the main Plasmac fold soon. I unfortunately also need IHS skipping that is not dependent on the last cut being under THC using the Auto Volts to set the cut point.
7 years 6 months ago #132132 by tommylight
Replied by tommylight on topic Another plasma component...
rodw wrote: Nobody has been able to achieve that with entry level plasma THC systems......
Wait, what ???
Entry level this is not in any way shape or form! Several times i have mentioned that the config i use will put most industrial systems to shame, this is much, much better. FYI, one of the clients i did a retrofit for, already has the second machine in use for quite some time, the Esab Ultrarex ( sold the first one, the guy who bought it calls me often for coffee or lunch as he is impressed with how easy to use and how reliable it is, never had a single issue ), he already bought another one in Germany that should arrive in a week or two to me retrofitted. All of them where in perfect working order when bought but usability was miserable, from several software issues to the second one using high frequency sensing for height control that failed many times every day to complaining about the gcode files being to big for complicate stuff he cuts. A 2 MB gcode file was to much for it. Granted those are older machines, still the reality remains, Linuxcnc controls every thing, those machines used several systems wired together to do the job, and using serial ports for communication voids the "real time" part.
The coffee guy mentioned above already has bought a 12x3 meter Hypertherm with a 400A power source that is sitting and collecting dust as he can not use it still, it will take him a lot of time to learn to use it. Looking forward to retrofitting that one! :)
The following user(s) said Thank You: rodw, thefabricator03
7 years 6 months ago #132140 by rodw
islander261 wrote: Rod
John, Seeing, Phill's away, the boys can play!
Try the attached component. there is a new pin called
skip_ihs_from_start
Setp it to a value of 1 and if you are really lucky, it should calculate the skip from the start position. Search for my initials "RJW" for the changes made. This is untested and I have not compiled it (written in notepad++ on Windows.) from the current GIT file.
I was a bit unsure exactly how to do it but I think plasmac needs an external_hold THC pin. THis could be permanently configured in Phills HAL stuff to always recognise M64/M65 via a digital output pin. This would let sheetcam to control it.
File Name: plasmac_20...7-2.comp
File Size:58 KB
7 years 6 months ago #132149 by islander261
Rod
Thanks for the solution. You have seen my PP so you know it can use both the synchronous digital outs (turn on) and static digital outs (turn off). The latest version of my PP puts both conditions where the static switch should have no effect on program speed.
I have thought about rolling my own IHS skip that doesn't require active THC and Auto Volts but don't want to go there just yet. I am really trying to stick with the commonly supported branch for the time being. I have my own fully custom adaption of Gmoccapy if I want to get back to the fix it with every update routine AGAIN. Phill is such a much better coder than I am for the present time I will wait for him to tell me to get lost before hacking his code.
The Plasmac branch is really so good now that I don't want to go polluting it with my hacking. This has the potential to kill a Texas loud mouth as soon as someone releases a pre built ISO with a schematic/wiring directions to use the Mesa hardware.
Time to create page: 1.500 seconds
