Another plasma component...
7 years 6 months ago #132391 by phillc54
John,
From what I see when the plasmac.skip-ihs-type == 1 the skip distance is calculated from the start of the last cut. This way the origin for distance follows with each cut instead of being fixed at the last successful probe (the last place we know where the material surface is). Once you start this it is very possible to chain many small cuts for a long distance before probing again. It is very likely that you can be several cuts removed from the last probing location and still be within the IHS skip distance.
So, skip-ihs-type 1 should be skip IHS if within skip-ihs-distance of last successful probe location?
Sorry if I wasn't clear about what is needed here. If the logic is inverted then THC-enable and IHS skip type == 1 can mean work with THC (from end of cut) and == 0 no THC, work from last probe. If the logic is inverted then I don't need two signals from Gcode to control it only the THC-enable from Gcode.
I am not quite sure what you mean here.
Cheers, Phill.
7 years 6 months ago #132392 by phillc54
Dee436 wrote:
1 I am using Debian wheezy with RTAI
I am also using all Mesa hardware including thcad
I wasn’t aware the Mesa cards required preempt_rt?
My system runs perfectly on 2.7 with RTAI, I just have no thc configured.
plasmac does run with RTAI, that is how I have been doing all my probe testing.
If you are using Mesa hardware then you will need PREEMPT_RT
Cheers, Phill
7 years 6 months ago #132393 by rodw
Dee436 wrote: 1 I am using Debian wheezy with RTAI
Getting the thc working was the reason for moving to plasmac.
Sorry, my mistake PREEMPT_RT is only required for ethernet Mesa cards like 7i76e
7 years 6 months ago #132394 by rodw
phillc54 wrote: John,
Cheers, Phill.
Phill, there may be a logic error in your thinking. It should not be the start of the last cut, but it has to be at the point the surface is last probed as thats the last place height was established. That could be a couple of cuts earlier if its all close together.
7 years 6 months ago #132397 by phillc54
Try the attached fix for skip IHS, I won't push until we are all good.
This was what I originally wrote...
I was thinking of four types:
1. within distance of end of last cut AND THC enabled
2. within distance of end of last cut AND THC disabled
3. within distance of start of last cut AND THC enabled
4. within distance of start of last cut AND THC disabled or enabled
I only did 1 and 4.
This fix is:
0 = within skip-ihs-distance of end of last cut AND THC enabled
1 = within skip-ihs-distance of last successfull probe
Cheers, Phill.
7 years 6 months ago #132401 by phillc54
Guys,
What is a typical LinuxCNC tool table for plasma?
Cheers, Phill.
Time to create page: 2.363 seconds
