- Thank you received: 4153
phillc54 wrote: If you don't already have a USER_M_PATH in your ini file [RS274NGC] section you will need:
And you need the M190 file in the config directory, unless you already have a USER_M_PATH in which case put the M190 file there.Code:# required for our material change USER_M_PATH = ./
Fixed. Very cool thank Phil
phillc54 wrote: Rod,
I have done a bit of work on your external thc-enable pin request and the best I can do is:
The plasmac component has an input pin named plasmac.thc-enable
The userspace run panel has an output pin named plasmac_thc.enable-out
These are netted together in plasmac_run.hal to a signal named plasmac:thc-enable
You could have a postgui halfile with something like:Or whatever logic you have for your requirements.Code:unlinkp plasmac_thc.enable-out loadrt or2 names=thc_or addf thc_or servo-thread net thc-in0 thc_or.in0 => plasmac_thc.enable-out net thc-in1 thc_or.in1 => my.hal-pin net plasmac:thc-enable thc_or.out
This doesn't break anything else so if it is good enough for what you want to do then I can push it later today.
Cheers, Phill
