- Thank you received: 216
John thanks for the report, according to my docs it IS supposed to reset to the "need to probe" state.islander261 wrote: Phill
The only problem is if you have an error and you are within the IHS skip distance the machine doesn't reset to the "need to probe" state when come out of the machine paused condition. Of course this is one of those corner conditions that I am probably the only one to ever come across in routine use. I just wanted to report this before I forgot about it. This sheet has 18 parts on it with 1017 pierces on the sheet.
phillc54 wrote: I think I prefer this way.
The gcode file is completely parsed before loading then it reports all tools that are not found and stops the program from loading.
It also makes for a cleaner gcode file as no code is required.
Cheers, Phill.
