Low budget plasma setup, what do I need?
30 Aug 2019 11:08 #143669 by tommylight
Replied by tommylight on topic Low budget plasma setup, what do I need?
Please explain your question.
Run your German question via Google Translate.
I suspect he is Polish working in Germany from the Pl in his nic and from his writing. I might be wrong......
30 Aug 2019 16:16 #143694 by rodw
Replied by rodw on topic Low budget plasma setup, what do I need?
Crimping is easy using HQ tools and 'correct' connector to cable in use !!!!
Does this help?
It never really matters in my experience if you use stranded or solid cable with the standard crimp connectors.
Everything will still be colour coded. Just determine if the cbale is wired to the A or B standard and make it straight through
  • tecno
  • tecno's Avatar Topic Author
  • Platinum Member
  • Platinum Member
31 Aug 2019 04:17 #143716 by tecno
Replied by tecno on topic Low budget plasma setup, what do I need?
Rod, there is a big difference in crimp quality if not using correct connectors. Two different beasts as regards the slotted prongs in the in the connector.
If using a stranded patch cable ALWAYS take a connector made for stranded wire!
31 Aug 2019 09:37 #143724 by pl7i92
Replied by pl7i92 on topic Low budget plasma setup, what do I need?
why dident you set the eth connector to a place you can connect from outside
plug on plug is always more risk to get EMI inside errors as of ....
there are cheep cable case thrus that fut tight and let pas ETH plugs while tighten the cable behind
  • tecno
  • Platinum Member
  • Platinum Member
31 Aug 2019 09:55 #143728 by tecno
Why, in my case that would not be done with parts I have in the 19" rack.
7i96 is too wide to the red card rails.
Yes I know there are several ways to skin a cat but I found this to be less expensive and easy to fit. Also I want the rack box to be totally with connectors on all cables for ease of storing and no tangling cables.
31 Aug 2019 10:04 #143730 by pl7i92
agree to you
its somtimes the best to do more work on cabeling to get a clener setup
  • tecno
  • Platinum Member
  • Platinum Member
01 Jan 2020 14:26 #153733 by tecno
Time to unplug the thumb from my a** ;)
Decided to shrink the working envelope to 500x500 and to skip rack/pinion and I will be using IGUS high helix screws instead.
Have had some issues with the driver box that now is sorted out so I can proceed with the software.
Cheers
Bengt
  • tecno
  • Platinum Member
  • Platinum Member
02 Jan 2020 14:01 #153810 by tecno
Some more sketching
02 Jan 2020 14:34 #153816 by chimeno
Replied by chimeno on topic Low budget plasma setup, what do I need?
Hi Tecno, it is a good idea to use IGUS high helix screw, I would like to see how they behave in steel dust environments.
Chimeno
  • tecno
  • Platinum Member
  • Platinum Member
02 Jan 2020 15:04 #153820 by tecno
Hi Chimeno,
The dust/smoke is something I am pondering on how to protect linear guides and the screws,
Not easy task but Iwill try ;)
Regards
Bengt
The following user(s) said Thank You: chimeno
Time to create page: 0.170 seconds
