New Plasma build question
- Clive S
- Thank you received: 486
13 Sep 2019 17:14 #145065
by Clive S
Replied by Clive S on topic New Plasma build question
Thanks to Dewey (dgarrett) and Peter (PCW)
I have made progress today. I can now home the machine including that gantry
When homed the gui changes to the normal 3 axis which is correct but then it won't let me jog any axis, the radio buttons do change with key presses correctly but no movement in DRO or motors.
I am also getting some following errors. I have tried with P value at 10 and 1000
I have not yet set the correct scale yet
- dgarrett
- Thank you received: 297
13 Sep 2019 18:11 #145069
by dgarrett
Replied by dgarrett on topic New Plasma build question
Your ini has:
Your ini restricts JOINT_0 to:Your ini restricts the corresponding identity
coordinate (X) to:
But the setting [JOINT_0]HOME=0 sets
X==JOINT_0==0 at homing completion which is within
the restrictions for JOINT_0 but not within the
restrictions for AXIS_X.
There are similar problems for the other axis
coordinates.
For identity kinematics (trivkins), one must make
the [AXIS_L]MIN_LIMIT,MAX_LIMIT less restrictive
than the corresponding [JOINT_N]MIN_LIMIT,MAX_LIMIT
It is generally simplest to make the
[AXIS_L]MIN_LIMIT,MAX_LIMIT the same as
the corresponding identity [JOINT_N] limits.
If you used a configuration tool to create the ini file
and haven't edited it, then the tool is broken in
allowing such a misconfiguration.
[KINS]
KINEMATICS = trivkins coordinates=XZYY kinstype=BOTH
[JOINT_0]
MIN_LIMIT = -1
MAX_LIMIT = 1200
HOME = 0
[AXIS_X]
MIN_LIMIT = 1
MAX_LIMIT = 1200Your ini restricts JOINT_0 to:
[JOINT_0]MIN_LIMIT <= X <= [JOINT_0]MAX_LIMIT
-1 <= X <= 1200coordinate (X) to:
[AXIS_X]MIN_LIMIT <= X <= [AXIS_X]MAX_LIMIT
1 <= X <= 1200But the setting [JOINT_0]HOME=0 sets
coordinates.
- Thank you received: 5316
13 Sep 2019 18:12 #145070
Replied by PCW on topic New Plasma build question
P (all joints) should be 1000
I would also set the maxerror numbers to 0
- Clive S
14 Sep 2019 14:31 #145135
by Clive S
Further update: With the above help I now have a good homing machine and can jog all axis when homed.
Now more questions. I get following errors if I try and increase the feed rate I can't get above 1000mm/min before it gives following errors.
The machine is good at distance commanded on all axis. But too slow. The drives are setup at 800 Iam using nema 34 with rack on x&y and nema 23 withball screw on z.
I have just notice this while writing
[EMC]
VERSION = 1.1
MACHINE = test2 This is not the machine name it should be plasma. Would this effect anything!!
how can I get the speed up without the following errors?
New files attached;-
[EMC]
VERSION = 1.1
14 Sep 2019 14:49 #145136
As a first step,
1. set all P values to 1000
2. all maxerror values to 0
3. fix joint 1's accelerations (stepgen value is the same as joint value)
- Clive S
14 Sep 2019 15:05 #145138
by Clive S
Peter Thanks for the rapid response.
I changed the P value to 1000 and maxerror to 0 - as you suggested yesterday. but had to change them to 10 for get rid of the following errors.
Not sure what you mean by this; fix joint 1's accelerations (stepgen value is the same as joint value)
As a first step,
14 Sep 2019 15:15 #145140
If P of 1000 causes a following error, the trouble is elsewhere
So set al P's to 1000
all max_errors to 0
in
[JOINT_1]
you have
MAX_ACCELERATION = 18
and
STEPGEN_MAX_ACC = 18
STEPGEN_MAX_ACC must be at least 20% larger that the joint limit
If, after these changes, you still get following errors, can you say (or copy/paste) the exact error?
I suspect something in the axis/joint velocity/accel limits is broken
As a next step, plotting the following error of the joint with an issue will
help pinpoint the problem
all max_errors to 0
in
[JOINT_1]
you have
and
- Clive S
14 Sep 2019 17:08 #145149
by Clive S
I have done as you suggested. Also formatted the ini a bit easier to read
The error is "joint 1 following error" This is when it is homing slow. It homed X ok then erred after Z started to home.
I also tried it with the sequence 0 Z first that erred the same
- Thank you received: 7465
14 Sep 2019 17:32 #145157
Replied by tommylight on topic New Plasma build question
The values for velocity and acceleration and stepgen_max_whatever must be the same for a given joint axis. In your ini they are all over the place.
Joint 0 must have same values as Axis X , etc.
- Clive S
14 Sep 2019 17:56 #145162
by Clive S
Thanks I have tried this;-
[AXIS_Z]
MIN_LIMIT = -100
MAX_LIMIT = 1
MAX_VELOCITY = 10
MAX_ACCELERATION = 12
[JOINT_1]
AXIS = Z
MIN_LIMIT = -100
MAX_LIMIT = 1
MAX_VELOCITY = 10
TYPE = LINEAR
SCALE = -200
STEPGEN_MAX_VEL = 10.0
STEPGEN_MAX_ACC = 12.0
FERROR = 1
MIN_FERROR = 0.25
DIRSETUP = 5000
DIRHOLD = 5000
STEPLEN = 5000
STEPSPACE = 5000
DEADBAND = 0
P = 1000
I = 0
D = 0
FF0 = 0
FF1 = 1
FF2 = 0.000127
BIAS = 0
MAX_OUTPUT = 0
MAX_ERROR = 0
HOME = 0
HOME_OFFSET = 2
HOME_SEARCH_VEL = 8
HOME_LATCH_VEL = 2
HOME_SEQUENCE = 1
HOME_USE_INDEX = False
HOME_IGNORE_LIMITS = True
With the same error
[AXIS_Z]
MIN_LIMIT = -100
MAX_LIMIT = 1
MAX_VELOCITY = 10
[JOINT_1]
AXIS = Z
MIN_LIMIT = -100
MAX_LIMIT = 1
MAX_VELOCITY = 10
TYPE = LINEAR
SCALE = -200
FERROR = 1
MIN_FERROR = 0.25
DIRSETUP = 5000
DIRHOLD = 5000
STEPLEN = 5000
STEPSPACE = 5000
DEADBAND = 0
P = 1000
I = 0
D = 0
FF0 = 0
FF1 = 1
FF2 = 0.000127
BIAS = 0
MAX_OUTPUT = 0
MAX_ERROR = 0
HOME = 0
HOME_OFFSET = 2
HOME_SEARCH_VEL = 8
HOME_LATCH_VEL = 2
HOME_SEQUENCE = 1
With the same error
Time to create page: 0.298 seconds
