My Newb Plasma Table Attempted Build
- dvn4life1972
- Thank you received: 173
19 May 2020 07:53 #168266
by dvn4life1972
Replied by dvn4life1972 on topic My Newb Plasma Table Attempted Build
Ah well about that lol...I got lost trying to figure out how to use halscope.
- phillc54
- Thank you received: 2100
19 May 2020 07:58 #168267
by phillc54
Replied by phillc54 on topic My Newb Plasma Table Attempted Build
There is a bit of a tutorial that may be of help.
linuxcnc.org/docs/html/hal/tutorial.html#_halscope
The following user(s) said Thank You: dvn4life1972
- dvn4life1972
19 May 2020 14:54 #168293
by dvn4life1972
I cut out several parts and followed that link to the instructions for halscope. I just can't get the dang thing to sample right or something. Also I don't have a signal listed for plasmac.axis z (the others are there). Halscope ran but I have no idea what the hell it's up to. I give up at this point.
- Thank you received: 4156
19 May 2020 16:35 #168301
Replied by rodw on topic My Newb Plasma Table Attempted Build
Until you get the hang of halscope, just set it to normal and roll up the top right. Also you have to scale things right or they will be to big to fit on the screen. Start with the vertical scale to be 50/div so to vertical lines will be 100 volts. Sometimes 20/div will also fit in. as far as the horizontal goes, 200 ms/div is a good setting.
- phillc54
19 May 2020 18:09 #168313
by phillc54
You could use plasmac.offset-current rather than plasmac.axis-z-position it will still let us know what the axis is supposed to be doing.
It is worthwhile perservering with it.I cut out several parts and followed that link to the instructions for halscope. I just can't get the dang thing to sample right or something. Also I don't have a signal listed for plasmac.axis z (the others are there). Halscope ran but I have no idea what the hell it's up to. I give up at this point.
- dvn4life1972
19 May 2020 18:21 #168314
by dvn4life1972
You guys are always great. I fully believe it's something I've done and/or something I'm doing wrong. Since my post of frustration earlier I've cut some more parts and used THC (haha).
It seems the faster the cut, on the longer cuts because that's when it flips out, the less it acts strange. I cut the same parts from some 16ga (was cutting from 10ga) at 230ipm and the THC seemed to work very well. So, I went back to 10ga and slower speed of 130ipm and towards the end if the border cut - the longest one - it slowly and continuously went upward.
I'm spent for the day. I'll give halscope another go tomorrow. I have some paying work stacking up now and it's 18ga and 20ga. I hope this crap gets resolved soon.
- phillc54
19 May 2020 18:39 #168315
by phillc54
Are the cut feed rates you are using from the cut charts?
- dvn4life1972
19 May 2020 18:47 - 19 May 2020 18:48 #168316
by dvn4life1972
Well, sorta. I'm running 60A consumables and the chart doesn't have anything for 16ga. I'm going to pick up some fine cut consumables in the morning which will mean much slower speeds.
Wherever I've found info in the charts I've been at or very close to hypertherms recommendations.
Last edit: 19 May 2020 18:48 by dvn4life1972.
- phillc54
19 May 2020 18:49 #168317
by phillc54
What machine is it and are you cutting at 60A?
- dvn4life1972
19 May 2020 19:40 #168321
by dvn4life1972
Hypertherm Powermax 1000 g3, and yes 60A.
Time to create page: 0.225 seconds
