Controller hardware suggestions for first DIY build
5 years 11 months ago #189425 by txtrone
rodw wrote: Normally if a motor has no data sheets, I'd say buy another motor but heck you have got them now.
I would probably get Longs Motor DM542A drives
I just ordered 4ea of these to use with my 7I76E card. DM542A
I will use my G540 with something else, I need to get my table running with LinuxCNC soon in order to begin working with the pneumatic actuators. Do you have any wiring diagrams for this stepper and the 7I76E?
5 years 11 months ago #189428 by rodw
Its very easy. Just connect the 4 step and direction wires. and the 48v power and shielded wires to the motor. Connect the shield to the cabinet frame ground and leave shield at the motor end unconnected.
DO NOT attach any wires to the DM542 enable connector.
The following user(s) said Thank You: txtrone
5 years 11 months ago #189433 by txtrone
rodw wrote: Its very easy. Just connect the 4 step and direction wires. and the 48v power and shielded wires to the motor. Connect the shield to the cabinet frame ground and leave shield at the motor end unconnected.
Are you describing the wires between the DM542A and the motor?
Which wires run between the DM542A and 7I76E and which wires run between the motor and the DM542A?
5 years 11 months ago #189436 by rodw
48v to DM542A . Connect the motor to the driver using a seperate shielded cable to each motor and the shield connected as I mentioned. Size the wires to carry the current given the length.
Then its just a matter of connecting +step & -step and +dir & -dir on the 7i76e to the DM542a. Hook up + to + and - to - for the step and direction signals
Do not use the DM542a ENA signal at all.
5 years 11 months ago #189440 by txtrone
rodw wrote: 48v to DM542A . Connect the motor to the driver using a seperate shielded cable to each motor and the shield connected as I mentioned. Size the wires to carry the current given the length.
Thanks!
5 years 10 months ago #192840 by txtrone
rodw wrote:
txtrone wrote: And also yes, grab the Mesa common connector you linked to. You can connect your 24V logic power + and - to the separate halves and then you can patch the power to wherever you need to for any inputs or outputs. It makes for a very compact design.
When you say '24V logic power' do you mean power from the PSU that supplies 24V to my Field Power and also supplies the board with power? Should I connect the Mesa DIN rail common halves to the + and - coming from the field power terminal? or straight to the 24V PSU?
Time to create page: 0.668 seconds
