Controller hardware suggestions for first DIY build
5 years 10 months ago #192852 by rodw
Sorry when I said Logic power, I should have said field power. Yes just connect the power supply to the BUS board and then patch across to the field power inputs. I used massive bus bars I could get locally as I had no idea those little Mesa parts existed. Its now super simple to wire in various relays and inputs via the bus bars
The following user(s) said Thank You: txtrone
5 years 10 months ago #192858 by txtrone
rodw wrote: Sorry when I said Logic power, I should have said field power. Yes just connect the power supply to the BUS board and then patch across to the field power inputs.
Ok, so go from the 24v PS to the Mesa BUS bars, then from their to field power?
If that is correct, how then would I then connect an PNP-NO proximity sensor? I looked at Norbert's schematic for the PNP, but it only shows connections based on NC.
5 years 10 months ago #192860 by rodw
So a prox sensor needs +24v and -24v so put them to the bus bar and then the output goes to an input. It does not matter if its NC or NO.
I mounted all my sensors on the moving gantry so I bought a couple of DB9 break out board thingies in the control box and used 9 core shielded cable to run common +24V and -24V up to the gantry ends and to the Z axis assembly and ran the inputs back on the other wires. On the Z axis, I made my own breakout board
See my spaceship:
forum.linuxcnc.org/show-your-stuff/32029...-build?start=0#84602
And revised later
forum.linuxcnc.org/show-your-stuff/32029...uild?start=130#91031
And becasue I bought NPN sensors, I added pull up resistors on that board.
I cheated on the gantry ends and just used a terminal strip on both sides. You can see a cable going thru the gantry rail to the other side to another similar setup
forum.linuxcnc.org/show-your-stuff/32029...uild?start=150#95275
5 years 10 months ago #192863 by txtrone
rodw wrote: So a prox sensor needs +24v and -24v so put them to the bus bar and then the output goes to an input. It does not matter if its NC or NO.
The spaceship is awesome! Also, FWIW, I enjoy telling my coworkers that I chatted with 'the Australian' and he explained it like this... me doing my best Australian accent
Would you mind sanity checking this for me? The blue and brown are the 24+ and 24- ... does it matter which is which? The black is the output wire that connects to the input on the Mesa card, right?
I am going to take the field wiring from the Mesa 7i76e and connect it to the Mesa din mounted 'common' bus bars. Then I will connect those bus bars to the 24v PSU. AND THEN I will connect these blue and brown wires to the 'common' bus bars, sound good?
5 years 10 months ago #192864 by tommylight
txtrone wrote: Also, FWIW, I enjoy telling my coworkers that I chatted with 'the Australian' and he explained it like this... me doing my best Australian accent
I also do that a lot, for plenty of Australians and from other countries, but i can not do accents, except say : iminem! :)
5 years 10 months ago #192867 by txtrone
tommylight wrote: I also do that a lot, for plenty of Australians and from other countries, but i can not do accents, except say : iminem! :)
hahaha ... glad I am not the only one!
Where abouts are you located?
Time to create page: 0.286 seconds
