- Thank you received: 7491
Controller hardware suggestions for first DIY build
- Online
Don't bother, it is over now !txtrone wrote: Now I want to research it.
It was messed up, badly, the whole ex Yugoslavia was a terrible mess. FYI, as luck would have it, i was in Croatia when the war started there, so till now i survived 2 f@kin wars !
Happy thoughts .....
- txtrone
- Thank you received: 106
tommylight wrote: FYI, as luck would have it, i was in Croatia when the war started there, so till now i survived 2 f@kin wars !
Damn, that is hardcore. I hope life is better now than ever for you.
- Online
- Thank you received: 4153
txtrone wrote:
rodw wrote: So a prox sensor needs +24v and -24v so put them to the bus bar and then the output goes to an input. It does not matter if its NC or NO.
The spaceship is awesome! Also, FWIW, I enjoy telling my coworkers that I chatted with 'the Australian' and he explained it like this... me doing my best Australian accent
Would you mind sanity checking this for me? The blue and brown are the 24+ and 24- ... does it matter which is which? The black is the output wire that connects to the input on the Mesa card, right?
I am going to take the field wiring from the Mesa 7i76e and connect it to the Mesa din mounted 'common' bus bars. Then I will connect those bus bars to the 24v PSU. AND THEN I will connect these blue and brown wires to the 'common' bus bars, sound good?
Yes prox sensors go blue to negative, brown to positive and black to mesa input.
Thanks for you comments re the spaceship. Spaceship Mk2 is evolving slowly.
Very cool. Not my fingers BTW.
As for Tommy, he is fluent in so many languages, it will take you all day to insult him!
- Online
To clean ???rodw wrote: Very cool. Not my fingers BTW.
Yeah, but getting rusty as i have no way of using them here, and since i can not travel, not really learning any other.
For reference: Albanian (native), Serbo-Croatian, English (of course), German, Czech, and a bit of Italian, very little Turkish and Bulgarian.
- Thank you received: 2177
I don't mean to be overly pedantic here but that would be 48V on the sensor. So just for the record -24V is not the same as 0V.
But yes I do realize that you mean the negative terminal of the 24V DC supply.
