RS485 For Hypertherms
  • thefabricator03
  • Visitor
  • Visitor
6 years 6 months ago - 6 years 6 months ago #163447 by thefabricator03
Replied by thefabricator03 on topic RS485 For Hypertherms
Ok, I have checked everything and I am not sure how this is working,
The card I am using,
www.sunix.com/en/product_detail.php?pid=135
And the connector I am using to the card,
The connector is just a straight through connector, no conversion of signals. The pins map to 1-5 on the DB9 connector.
I was under the impression that this was the brains of the conversion for the USB to RS485 converter.
Not sure how it is working but it is working for me.
Last edit: 6 years 6 months ago by thefabricator03.
6 years 6 months ago - 6 years 6 months ago #163457 by phillc54
Replied by phillc54 on topic RS485 For Hypertherms
Magic... ;)
snowgoer540 wrote:
I will test it tomorrow morning
This one may be a bit closer although there are still some issues.
I won't be able to complete this until I update the firmware in my "Powermax"
Last edit: 6 years 6 months ago by phillc54. Reason: forgot the attachment
6 years 6 months ago #163511 by snowgoer540
Replied by snowgoer540 on topic RS485 For Hypertherms
thefabricator03 wrote: Not sure how it is working but it is working for me.
Haha, me either. Although in my search for the answer, I was able to find a pdf for a card (attached) that uses the same SUN1889 serial chip as your card. The PDF shows that the chip IS capable of RS-485, even though the manual for the card you have says it is RS-232 specific.
So it would seem that my card claimed it CAN do RS-485 and CANT, and your card claimed it CANT do RS-485 and CAN. :laugh:
At any rate, I ended up hooking mine up to the COM header on the motherboard. I haven't tried to use it without the converter, maybe I'd be in the same boat. I'll try it later when I try Phill's new code. Mostly out of curiosity.
6 years 6 months ago - 6 years 6 months ago #163525 by snowgoer540
Magic... ;)
This does look better! Question, I see in the terminal now you are reading min pressure, do you read the max pressure as well? Maybe that's in the works, just trying to follow along.
Bars for different modes:
Normal ==> 4.3-5.4
CPA ==> 4.3-5.4
Gouge ==> 3.0-4.0
One other observation: When you change between modes, for Normal and CPA, it defaults to the lowest pressure possible. For Gouge, it defaults to the highest pressure possible. One suggestion would be that when you change modes it should probably go back to 0 as to put it into automagic mode. Then the user could change settings from there. I know this is just a tester, but I would assume you're going to carry most if not all of this over to Plasmac after it's sorted out, so thought I'd mention it.
-Greg
Edit: Might want to hit up Jim Colt if your Pmax0000 doesnt take the firmware flash. That guy's pretty helpful when it comes to hypertherms :)
Last edit: 6 years 6 months ago by snowgoer540.
6 years 6 months ago #163534 by snowgoer540
rodw wrote:
snowgoer540 wrote: EDIT: Proper units LOL made me chuckle. What was that saying? Two types of countries, those who use the metric system, and those who have been to the moon :)
You also seem to forget the moon goers lost a spaceship because they did not use those proper (SI) units.
Did you know that only three countries in the world don't use SI units? And one of them has made the decision to convert. Here is an interesting map and worth a read.
www.zmescience.com/other/map-of-countrie...g-the-metric-system/
Haha, no bias in that article at all :laugh:
Seriously though, I think it is about frame of reference. I know how much a pound is, a inch, a foot, etc. Having to learn that all over again would suck. That said we do use metric on some of our vehicle programs at work. I will admit, it is easier to work with the numbers. I just have no frame of reference.
6 years 6 months ago #163539 by phillc54
snowgoer540 wrote: I see in the terminal now you are reading min pressure, do you read the max pressure as well? Maybe that's in the works, just trying to follow along.
Yes it reads max and min pressure plus max and min current. Don't worry too much about stuff in the terminal, that is just for me while I am testing. You should see the correct values in the port tester
Yes, I ended up at that conclusion yesterday. At the moment it depends on what the current settings are and whether they fit within the new modes limits so it seems a bit random. Setting it to zero before sending the mode change should fix that. It is difficult to test because I can't see how a real PM behaves on a mode change, I am only guessing.
Yes, I figured it would be easier to sort out on the port tester first.
Time to create page: 0.431 seconds
