RS485 For Hypertherms
6 years 6 months ago #163560 by phillc54
Replied by phillc54 on topic RS485 For Hypertherms
snowgoer540 wrote: Basically everything looks great, and works exactly like I would expect. Only thing I noticed: I had a fault (0-22-0) because I didn't have the shop air valve open, and after I opened it and the fault cleared on the PM Panel, it never went away on the powermax communicator interface. I think they cleared in the past, but this time no luck.
I thought so too, I'll check it out
One other thing, I wanted to check the metric units (bars ... evidently not a place to get a beer), and I cant remember for the life of me how to do that. I cant find it in the manual, and the serial protocol manual seems to be in PSI. Am I missing something, or are you going to have to display for the metric folks via a conversion?
Do they even have bar?. I have no clue but if they don't then I am not going to try to convert it.
Otherwise, great work as always, and I owe you a pint! :)
Or 473.176mL ;)
I could change over in my little shop, where I do mostly work for myself, but even if I did change over, Most customers I took on would look at me cross eyed, and probably avoid me because I asked them if they want a 25.4mm hole instead of saying 1 inch
Of course, you need to use the system suits your location.
6 years 6 months ago - 6 years 6 months ago #163561 by snowgoer540
Replied by snowgoer540 on topic RS485 For Hypertherms
phillc54 wrote: I thought so too, I'll check it out
Sounds good. I’m headed to bed but if there’s any updates I’ll test them in the AM.
The display shows both units when in manual mode. I’m not sure though if it reports via serial in bar at all or just PSI.
Or 473.176mL ;)
Let’s just call it an even 16 oz. lol
Have a good evening
Last edit: 6 years 6 months ago by snowgoer540.
6 years 6 months ago - 6 years 6 months ago #163563 by phillc54
@Stefan and @Greg
OK, I have most of the fixes done in the main code but I have a couple of questions.
Should I set the current to be in 1Amp increments/resolution rather the 0.1
Should I set the pressure to be in 1psi increments/resolution rather the 0.1
If Bar does exist in the Powermax units (how do I find out?) then for Bar set the pressure to be in 0.1Bar increments/resolution.
I have it set so that if there is a mode change while connected to the Powermax it will set the pressure to 0 before changing the mode, thus setting the pressure to automatic.
The tooltip text is now dependent on whether or not the Powermax is connected.
Last edit: 6 years 6 months ago by phillc54.
6 years 6 months ago - 6 years 6 months ago #163566 by rodw
Replied by rodw on topic RS485 For Hypertherms
My book on the HT RS485 only shows PSI for pressure.
actually bar is a bastard term invented by some meteorologist and is not an SI unit (System Internationale). The Pascal is the correct unit. I always thought a bar was 1 atmosphere but its not quite. Its 100 kPa. 1 atmosphere is 101.325 kPa. But I do see bar is used on my thermal dynamics plasma.
When I studied engineering in 1978, in one of the first lectures, the lecturer calculated horsepower and filled 2 blackboards. Then he redid the calculation in kW in about 4 lines and announced "And that why here in Australia we use SI units." I had never even heard of SI until then!
Last edit: 6 years 6 months ago by rodw.
6 years 6 months ago #163569 by snowgoer540
phillc54 wrote: @Stefan and @Greg
As it turns out I can’t sleep..
I say yes to both 1 amp and 1 psi increments as the PM can’t display any finer resolution than that, and I agree with Stefan that I doubt it makes any appreciable difference in the cut anyhow.
I agree, bar needs to be 0.1 increments. I’m really not sure if it can tell via serial if you want psi or bar to be reported. I’m willing to do a little more digging as I swear there was a place to change default units (on the PM itself). Maybe I dreamed it though. One thought would be to just copy the environment the user changes for plasmac. If the user prefers SI as the default units, calculate a conversion to bar to the nearest tenth? I imagine most of the time changing from automatic mode won’t be necessary anyhow.
I think that’s probably the best method for changing between modes. Like I say, I’d think that 99% of the time the end user won’t mess with pressure. Hypertherm spent a lot of time and charges a lot of money for having these things right to ensure the power sources “just work”.
Good deal on the tool tips. I’m looking forward to testing it all out.
6 years 6 months ago #163570 by tommylight
Replied by tommylight on topic RS485 For Hypertherms
snowgoer540 wrote: The conversion to imperial units is still roughly somewhere between an inch and the moon... which we landed on :P
In all seriousness, I agree with you all. It's just the way it is here, and there isn't much I can do but be assimilated... resistance is futile.
You keep mentioning you got to the moon, kudos for that, but you forgot to do your homework, NASA uses metric since their start.
So thank you ! :) Oh and US Navy, too, clicks they keep referring too are kilometres, and mill dot on the sniper rifles is in metric, always.
Time to create page: 1.592 seconds
