RS485 For Hypertherms
6 years 6 months ago #163698 by phillc54
Replied by phillc54 on topic RS485 For Hypertherms
One more question with regard to updating. Is there a place that shows what version I am on? I had previously remembered a build in the window header, but mine just says "AXIS 2.9.0~pre0 on Plasma". Was thinking it would be nice if there was a definitive way to tell I'm running the latest. Maybe in the help about, or in the Config tab?
From a terminal run
$ man plasmac
You would need to run rip-environment before you did that. If you don't like:
$ . ~/linuxcnc-dev-scripts-rip-environment
you could run:
$ source ~/linuxcnc-dev-scripts-rip-environment
the . is a just shotcut for source
1. The very first time I enabled comms after updating, I couldn't change the gas pressure to anything but 0. Changing modes seems to have fixed it, but it seems like there might be a bug there that needs to be squished.
2. The tooltip for hovering over amps remained the same whether or not comms was enabled. This went away like the issue above when I changed modes, and restarted Plasmac. All the other new tool tips just worked the first time though, so not sure what was up there.
Bizarre, it runs fine here. Gas pressure won't change until comms is established, are you sure it was.
6 years 6 months ago #163701 by snowgoer540
Replied by snowgoer540 on topic RS485 For Hypertherms
From a terminal run
$ man plasmac
you could run:
So what does the RIP environment script do then exactly? Maybe that a hang up in my head.
Yea comms were established because I could change amperage and at that exact moment I was verifying error messages came and went.
Actually, it started with an error message, and everything started working right when it cleared, and I switched modes. I wonder if the two are related now. I could try to reproduce it in the morning.
6 years 6 months ago #163704 by phillc54
snowgoer540 wrote: So what does the RIP environment script do then exactly? Maybe that a hang up in my head.
It sets up the environment variables like PATH etc. to point to the RIP version of LinuxCNC rather than where an expected installed version would be.
From rip-environment script the new environment is valid for only that terminal session.
From the linuxcnc script (the one you used) the new environment is valid for only that run of LinuxCNC.
Current may be changed at any time, it is not dependent on communications.
Let me know how it goes.
6 years 6 months ago #163708 by snowgoer540
phillc54 wrote: It sets up the environment variables like PATH etc. to point to the RIP version of LinuxCNC rather than where an expected installed version would be.
That makes sense. Thank you for clarifying. One more question about the RIP (for now :)) what about pncconf? Is that always running from the installed version?
Sorry I wasn’t clear there. I could see the amperage changing in the PM panel.
Will do!
6 years 6 months ago #163711 by tommylight
Replied by tommylight on topic RS485 For Hypertherms
snowgoer540 wrote:
phillc54 wrote: Won't the LinuxCNC packages from the buildbot run on Mint?
I’m not sure, I think Rob said it wouldn’t. I’m willing to try (I don’t know the repercussions...).
I always use Mint with Mate or XFCE, and i always use the buildbot packages for Stretch, it always works.
Yesterday it worked for a friend through the phone, and he is very challenged in the "follow directions" department, example:
Me: right click on the linuxcnc-userspace-something-something-amd64.deb and clock on save link as. Now double click on that from the file explorer, what does it say?
Him: Nothing!
Me:did it open a new window?
Him: yes
Me: what's on that window?
Him:nothing, same links as on that page i downloaded from.
Me: not the bloody save page as from the menu, right click on the link, right click..........
It was a long day, but he got it eventually.
6 years 6 months ago #163712 by phillc54
All executables will run from where your environment PATH is pointed.
You can check this yourself, open up two terminals, in one terminal type:
$ which pncconf
in the other terminal type:
$ source ~/linuxcnc-dev/scripts/rip-environment $ which pncconf
you will see they are both from different locations.
Time to create page: 0.857 seconds
