RS485 For Hypertherms
6 years 6 months ago #163540 by tommylight
Replied by tommylight on topic RS485 For Hypertherms
You had to pull me in on this, did you ?
It is astonishing how some people (not referring to any nation or sort of) are poised to protect their own miss..... whatever, not just the wrong system, but also driving on the left side while the rest of the world drives on the right, some nations and religions thinking they are goods gift to earth and that only they have the right to everything, etc etc.
There was a documentary on youtube about imperial system and the losses the US economy suffers from using it every year ( enter some random number here with lots of zeros ), but still refuse to switch to metric. It also had a nice showcase with 3 of the machinist that work for American Chopper, they spent 13 minutes trying to figure out how much should a pipe be cut based on the measurements of the space it has to fit and the length it actually is, they did not figure out, they gave up and just did it by eyeballing it.
And a gallon is not a gallon, an ounce is not an ounce, well there are several ounces.
Same goes for electricity, they still use 110V, requiring much thicker cables and transformers every 100 to 200 meters, not being able to use high power machines, not being able to quick charge the Tesla in their garage, etc etc, oh and lots and lots of fires due to the old way of installation, overloaded transformers, old types of equipment............. and the list goes on. I'll shut up before i delve into the way of building houses and materials used, and some other stuff.
I better go hide now. :)
6 years 6 months ago #163541 by rodw
Replied by rodw on topic RS485 For Hypertherms
snowgoer540 wrote: [
Seriously though, I think it is about frame of reference. I know how much a pound is, a inch, a foot, etc. Having to learn that all over again would suck.
It did but we managed. And the conversion rates are still embedded in my brain.
Its not actually simple measurements and weights that really matter, its the derived units like the kN of force to loose a rocket ship or pressure or acceleration that the SI units really come in to its own. Engineering maths is so much simpler.
But for the last 20 years, I banished Imperial units from my world and life has been good.
And selecting sa drill to tap a thread is so simple. No need fro charts. Say M10 x 1.5 pitch thread just needs a 10mm - 1.5mm = 8.5mm drill!
  • thefabricator03
  • Visitor
  • Visitor
6 years 6 months ago - 6 years 6 months ago #163542 by thefabricator03
Replied by thefabricator03 on topic RS485 For Hypertherms
rodw wrote: But for the last 20 years, I banished Imperial units from my world and life has been good.
I am trying to do what you have done and banish everything except metric units but other dont want to participate.
Example, we use a lot of Gal coated CHS pipe. The steel supliers call it by Nominal bore. But when we draw up the pipe in our 3D cad program we use mm, so 33.7x2.6 OD pipe becomes 25 Nominal bore in Light thickness. But the thickness designations with different size pipes do not line up. 48.3x2.9 OD pipe is called 40 Nominal bore in light.
It really does my head in.:blink:
Last edit: 6 years 6 months ago by thefabricator03.
6 years 6 months ago #163544 by phillc54
Replied by phillc54 on topic RS485 For Hypertherms
Buy some modern day pipe. :laugh:
  • thefabricator03
  • Visitor
  • Visitor
6 years 6 months ago - 6 years 6 months ago #163545 by thefabricator03
phillc54 wrote: Buy some modern day pipe. :laugh:
LOL, If I could I sure as hell would! RHS,SHS, Flat bar all conform to metric sizes. Pipe seems to do its own thing.
  • thefabricator03
  • Visitor
  • Visitor
6 years 6 months ago - 6 years 6 months ago #163546 by thefabricator03
tommylight wrote: It also had a nice showcase with 3 of the machinist that work for American Chopper, they spent 13 minutes trying to figure out how much should a pipe be cut based on the measurements of the space it has to fit and the length it actually is, they did not figure out, they gave up and just did it by eyeballing it.
I watched that for the first time back in 2004,
Believe it or not but that show heavily influenced my decision to start a welding/fabrication apprenticeship back in 2006. I love making things. But only using metric units lol
Time to create page: 2.206 seconds
