RS485 For Hypertherms
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
17 Mar 2020 23:28 #160603 by phillc54
Replied by phillc54 on topic RS485 For Hypertherms
Please find attached the diagram, If you need anything changed let me know.
Thanks Stefan, could you:
remove "Jaycar P/N: " and just leave "XC4136" as that seems to be a common part number for that product.
change: "RS232 PCI Card using same connector as on about USB/RS485 Converter"
to: "RS232 PCI Card using same connector as the above USB/RS485 Converter"
and I will put in as is.
  • thefabricator03
  • thefabricator03's Avatar
  • Visitor
  • Visitor
18 Mar 2020 06:31 #160620 by thefabricator03
Replied by thefabricator03 on topic RS485 For Hypertherms
All done Phil. Please see attached.
  • thefabricator03
  • Visitor
  • Visitor
18 Mar 2020 06:35 #160621 by thefabricator03
This looks good, and is very helpful! It may be prudent to show how the 5 pins on the terminal block shown correspond to the actual DB9 connector in the event that the 5 pin terminal block connector isnt available. I can only find 9 pin terminal block versions on Amazon. Although I believe your chart does have enough description to get you there.
Just a thought! Thanks again.
Just something I thought of. I am not sure if all of the RS232 cards have the same DB9 pins for the same signals. Maybe if someone can confirm that is a standard, I will map my DB9 connector and post the pinout. I just dont have a lot of time to research that at the moment.
  • phillc54
  • Platinum Member
  • Platinum Member
18 Mar 2020 06:39 - 18 Mar 2020 06:40 #160622 by phillc54
The RS232 pins are standard although whether the pins for adapters are standard I have no idea.
Edit: Does this relate to yours opengear.zendesk.com/hc/en-us/articles/2...-DB-connector-pinout
Last edit: 18 Mar 2020 06:40 by phillc54.
  • thefabricator03
  • Visitor
  • Visitor
18 Mar 2020 06:40 #160623 by thefabricator03
Ok I will map the my connector pins tomorrow and modify the reference doc. I will just make a note that it is specifically for that connector.
  • phillc54
  • Platinum Member
  • Platinum Member
18 Mar 2020 06:42 #160624 by phillc54
Did you see the link in the previous post.
I don't think it is worth worrying about, so long as the pin function is known is should be no problem.
  • thefabricator03
  • Visitor
  • Visitor
18 Mar 2020 07:37 #160627 by thefabricator03
Ok, yeah I think the main thing is knowing the pinout on the plasma unit and if you create your own DB9 plug you would just need to map the correct signals together. The reference doc does show the mapping so most people should be able to figure it out.:)
  • phillc54
  • Platinum Member
  • Platinum Member
18 Mar 2020 08:30 #160634 by phillc54
Here you go, linuxcnc.org/docs/devel/html/plasma/plas...-guide.html#pm_comms has a link to the diagram.
The following user(s) said Thank You: thefabricator03, CNCFred
  • Moderator
  • Moderator
18 Mar 2020 11:06 #160641 by tommylight
Replied by tommylight on topic RS485 For Hypertherms
Just had a look at that PDF and saw the PCI to serial card, i must have had over 30 of them! Most probably already thrown them as i have a strong aversion to anything RS232 from the days of 9.6K modems ! I took them out of some massive DVR's i installed in some shopping centers in two cities here.
Will check promptly if i have any left, and will do a giveaway if anyone needs them.
The following user(s) said Thank You: phillc54, thefabricator03
31 Mar 2020 20:58 #162295 by alexandrub
Replied by alexandrub on topic RS485 For Hypertherms
I made the comunication with an usb to rs485 from Icp-con 7561. It is working but i want to verify something. In material table i define a material with 45a and 128v. I start the process , everything if fine but in the voltage field in Plasmac i see only 60v. How can i verify where is the problem? I let the voltage divider on Powermax at 1:20, i made some test with a adjustable power source on the thc and seems to be fine...in this case if the voltage is not real in Plasmac, the thc is not working in real condition i think.
Time to create page: 0.756 seconds
