RS485 For Hypertherms
- Thank you received: 7501
There is a big diference in cutting nozles for hand and machine cutting in that the machine one is much longer directing the gases and removing whirl.
As for cleaning i have never seen any of my clients clean it, most probably due to all that pressure not allowing anything to stick to it and the distance from the material, the distance is much bigger than with plasma, roughly 5mm above from what i saw.
Again, it is advisable to double check this as i have done very litle cutting with it.
Then again, seeing 100mm thick piece of metal cut relativly clean is quite amazing !
- grijalvap
- Thank you received: 63
- phillc54
- Thank you received: 2100
- Thank you received: 4154
Stefan is currently testing this feature.
Maybe you should also get grijalvap to test this as he wrote the original Python script that has been incorporated into Plasmac.
- phillc54
email introduction sentThe more the merrier.
- Lunkwill
I'm glad to hear serial support is in progress. Is the end goal to dynamically reduce current when turning corners to reduce dross?
Now thats an interesting idea. I'm not sure if the 19,200 baud serial interface is fast enough. With a 18-20 byte packet to set the current, that will take about 10 milliseconds to send, plus any latency in the plasma cutter to change the current. Somewhere also the plasma cutter sends back an acknowledgement packet so another 10 ms.
- Lunkwill
"That lets you define a lower/slower pierce current /speed and can increase consumable life by at least double. Part of that is the "Soft Peck" that lets you turn down the current when pecking the centers of holes for drilling later. Marks, but does not pierce the metal."
"you can for example set up a Cut Rule (in SheetCAM) that lowers the feedrate on every corner, lowers the cut current and even turns off the DTHC as it does around the corner then puts everything back to you normal settings on the other side"
"Corner Current Percent
The Corner Current Percent feature allows the operator to select a reduced current setting to be executed when cutting corners to improve cut quality. This value is a percentage of the Set Current ( above ) and is active when the Torch Height Disable Output is on. The Corner Current parameter is also available for the HD4070® via the serial link."
Dynamic cut control: www.candcnc.net/images/Manuals/DTHCII_HyT-ConnectDCC.pdf
- phillc54
There is no guarantee of when the new setting would take effect.Real-time updates are not recommended because system response times vary based on the application being performed and the commands being issued. Powermax systems enable you to update some control settings – such as cutting current and gas pressure – even while the torch is cutting. However, testing should be performed to make sure that system response times are adequate for your applications.
